busting poly locks
Results 1 to 13 of 13
busting poly locks
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default busting poly locks
    I got some poly locks that busted on the machined part where they meet the rocker arm. I have a good stud girdle studs are 1.75 long screw .355 into poly lock witch is less than .4375 7/16. Ordered some 2.1" studs 2.3 would leave .900 threads above rocker arm. Nut wouldn't tighten up on them. Any body else ever had this problem?
    Tri-Cities, TN
    Whose poly locks? What was the torque on the jam nut?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Derby, Kansas
    Quote Originally Posted by vmaxed View Post
    If you over torque that set screw they seem to break there from what I've seen. The set screw should need much if any torque since the girdle should keep the poly lock from turning.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    See if the top of the stud is smooth or indented. Those things are cast and there are a lot of junk ones around. Tightening the poly lock against the set screw is asking for it.
    QE 439 Twin Turbo
    Sep 2010
    Default locks
    CS don't know who made the first set came with Comp Cam setup. The set on it now came from Lunati. I tighten them with a t-handle surly I ain't over tightening them. Hope the .350 longer stud helps.
    Tri-Cities, TN
    15#/ft is max you want to torque the set screw.
    Chris Straub
    Straub Technologies
    Sep 2010
    Default woooo
    Dang I did not know that. New ARP studs should be here to day. Hope they are flat on top. Pain in the but to start from scratch. I run them twice if I have the girdle off.
    Grady
    San Francisco Bay Area
    Cool
    Errr, are you sure the rocker arm trunnion isn't 180* out on the polylocks that are breaking down there? Also, make sure the rear of the rocker body is not contacting the polylock at full valve lift.
    I suggest you step up to a 1.900" stud for your valve train combo; the stud's thread depth into the polylock should be 1-1/2 times the stud diameter (not to suggest that this is part of your polylock failure issue).
    LO
    High Flow Dynamics
    Jan 2011
    Mickleton, New Jersey
    no
    Oct 2010
    661 So. Cal.
    This 👍
    Sent from that vibrating thing In your pocket using Tapatalk
    Default Busting, or splitting??
    Quote Originally Posted by LakesOnly View Post
    LO
    My first thought as well... The only ones I've seen fail were tightened against the rounded portion of the trunnion, and they were split open rather than actually broken. If you're breaking them to the point of pieces falling off and they're tightened against the counterbore correctly, I'd lean towards them being defective. Maybe over heat treated to the point of being brittle?? Hopefully the ARPs will solve your problem, but look things over carefully for solid metal to metal contact at full lift, and remember, the springs and valves are really dancing around during operation. (a slow motion video will scare you to death when you see what is really happening to your valve train)....
    Ray
    LOUD BOATS SAVE LIVES
    Sep 2010
    Default we will see
    Put the 2.1" studs in last night. I now have over .550 of thread sticking through the rocker arm. The old ones hah .350 all the material inside the rocker was threaded except about .100. Five of them were marred and wouldn't pull through the rocker. One was even bent. Now all but about .200 of the stud in the rocker is the smooth boss. I also made sure I didn't over tighten the jam. Everything seems to be friendly now.
    Mar 2010
    Clarksville, TN
    Are all you Arki guys like a Bull in a China Shop
    LMAO !!!!!!!
