Valve Covers with no holes?
Results 1 to 12 of 12
    Senior Member Sharkbit's Avatar
    Jan 2010
    Default Valve Covers with no holes?
    What are you guys using for an oil fill and for evac fittings? Would like to use AN fittings for evacs.
    waterloo
    The AN stuff looks cool.... but it is heavy and expensive.
    The fuel guys use some flimsy tubing. It doesn't even stay expanded when no blow by. Light, though. I have seen guys use pvc tubing... or vinyl tubing?? and braided tubing. All sorts of stuff. Use what you like.
    I just have breathers. I am a rebel and rule ignorer. HA
    Wags
    If you really want bitchin buy those 1/2 turn tube lock deals by SAE and run some bad ass tubing.
    waterloo
    waterloo
    This is the tube I have seen. It doesn't have any pressure. IF you are using it on a vacuum pump, this obviously won't work. IF for breather only... light.
    Any industrial hose supply place will have a variety of hoses, thicknesses, colors, etc to chose from.
    Wags
    EVAC BAFFLE FITTING USUALLY INSTALLED IN THE FRONT OF THE COVER
    REX MARINE SELLS THESE USES A -16 O-RING FITTING.
    OIL FILL
    Who makes those and who sells them?
    waterloo
    They are made by SAE. I saw them in Speed Sports pits... he has some...This pic came from RBS Superchargers...
    Burn Down Breathers
    Several options on this page. I like em cause the hoses pull off quick. WARNING... on a fuel boat it is recmmended to put duct tape over the 1/2 turn clamp deals.
    Jan 2012
    lake Charles, Louisiana
    If running 1 1/4 lines, these burn down adapter work great
    Burndown Tubes
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    We use a standard rubber grommet. A 3/4 NPT AN fitting threads right into it.
    You can buy an oil fill with a built in grommet just bore the correct hole.
    This works great for plain stuff. No vacuum pump
    QE 439 Twin Turbo
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by Sharkbit View Post
    Dry sump tank, evac with AN fittings
    Quote Originally Posted by jimclauss View Post
    Geez Jim, the dyno forum was going for 12 straight hours without a post and you went and blew it by 10 freek'n minutes!
    Whats up with that!??
    Jan 2011
    thats now I roll
