[Question] 454 GM block and Heads
Results 1 to 6 of 6
    Nov 2008
    Default 454 GM block and Heads
    I have a GM Marine Power 7.4/454HO motor and was needing some info on the block and heads.
    2 bolt or 4
    Pistons ?
    Cam ?
    GM Block part # 12568777
    date 02-2001
    Serial #07075
    Head casting #12562934
    I think the heads are open chamber 502 marine, would like to know valve size, cc of heads(118cc).
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    i could find info on the block,
    google it
    The casting number is usually easier to find information with, as opposed to the part number,, not sure if you missed a digit or what, wouldn't come up for me. A 2001 block should end up being a 4 bolt Gen 6 block.
    Led
    Led is offline
    Jul 2010
    the casting number is close but not showing in the lists i looked at, i am leaning the same, 01 Gen 6
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    mine was a 97 7.4 in my baja. 4 bolt main, hyd roller. I think 330hp- gen 6 block
    Nov 2008
    Thanks for the info!
