Factory cast iron vs alum logs, any difference
Results 1 to 5 of 5
    Oct 2011
    Default Factory cast iron vs alum logs, any difference
    Got a PCM 454 330hp with some rusty iron factory manifold/risers. I also have some old alum logs with snails available. Is there any performance difference between these two options? I realize that neither are great for high performance apps but was just wondering if going to the logs would have a detrimental effect......
    Orlando.FL
    Certainley the weight factor is. depends on the style used as their are many.
    Oct 2011
    The cast units are center riser and the alum's are the old M1's if that gives you any info! I'm mainly wondering the effect at low to mid range rpm's.
    Oct 2011
    whoops, actually M2-4's
    At 330 hp, it wont be a big power robber. You may sense a little soggy-er throttle on the bottom-mid. The center risers have a little bit more primary lenth which helps the throttle response.. The logs look better and are lighter. Run um!
