Procharged 502
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 50
Procharged 502
    Chico, Ca
    Default Procharged 502
    I have had my procharged 502 built for while now, but life had put it on hold. Finally got some new progress on it. I took off the MS2 I originally built for it and setup a better megasquirt product. I built a custom cam sync from junkyard parts and my msd distributor plug I was using before. Had a few issues I had to sort out and then found the intercooler was junk. I'll be back at it on Monday and will report back with some more info.
    Andrew
    Placentia, CA
    After building a custom cam sync deal similar to yours, I have acquired 2 of the MSD 8514's on e-bay, new and never run!
    steveo143 AKA DiMarco 21 II
    Chico, Ca
    Yeah I've seen some of those for sale, but I've heard they were terribly unreliable and failed often, specifically with water intrusion, which is why they were discontinued. I passed on them for that reason.
    Chico, Ca
    It's e85 on with these pulleys. I have other pulleys that should only be in the 8-10lbs range and then it can be switched to pump gas.
    Placentia, CA
    I will seal my MSD units and run all 3 on a distributor machine and check them out, at least I have backups!
    okie, lake Texoma
    Looks good Andrew. What are your expectations? cant wait to see how she does.
    H8-2-W8
    [email protected] first pass
    Chico, Ca
    So much depends on how much boost it ends up making. When I talked to procharger many years ago, they said with my setup and pulleys it should make 16-18lbs of boost. By my calculations that boost should get it to around 1200hp or so. I'm not too worried about getting any more than that. It's going in a cruiser anyways!
    okie, lake Texoma
    If it'll make that much boost I believe you should make your goal. Good Luck, and let us know how it does.
    Hass
    H8-2-W8
    Chico, Ca
    This blower can push 2200 cfm and 35psi. That's good for about 1600 hp. 1200hp at just under 20psi should be easy for the blower. Really have no desire for any more power than that though. Likely ill turn it down right away...as I planned to run low boost anyways.
    Tower Park Resort, Lodi, CA
    Do tell. MS3 or what? What had you change?
    Chico, Ca
    Yeah it's an MS3, full sequential, 36-1 crank wheel, cam is a 50/50 hall effect trigger, ls1 coils, 135lb injectors.
    Andrew
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Awesome. Where did you get that hall effect sensor?
    QE 439 Twin Turbo
    New here Beer:30's Avatar
    Bakersfield, CA
    Andrew
    Awesome hardware. Assuming this is for a boat - are you going to run full-time O2s in the boat (closed loop)?
