Carbon on pistons
Results 1 to 13 of 13
Carbon on pistons
    Q.C./Big River
    Default Carbon on pistons
    A good burn in the cylinder means the whole piston should be covered with carbon correct? What if only the bottom 3/4 of the piston in each cylinder had carbon build up? Would this mean that a complete burn is not being achieved? If so why would it happen and how would you tune or correct for a complete burn?
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Buy a FORD.. problem solved
    Could be a number of thigs, but typically it's related to chamber design and cylinder filling. It's one reason we wet flow cylinder heads, to see just where the fluid is going.
    What heads? Is there a dome on the piston?
    Q.C./Big River
    Quote Originally Posted by PlacecraftTunnel View Post
    No I would start breaking piston rings then!
    Q.C./Big River
    RHS 360's and yes there is a dome but I am not sure ehat size exactly. I would have to dig through the build paperwork to find the piston specs.
    It can be caused by a very tight quench and a cold head. Is not real uncommon in boat engines. Less so in a car.
    But if your talking about WASHED, thats another story.
    Q.C./Big River
    Thats what I was looking for. I figured as much. Pistons out of the hole .015 with a .042 gasket is a tight quench. The motor is never run with cold heads though.
    Yeah, that could explain it. Thats pretty tight!
    You say never run with cold heads. You mean you run the motor at 180 plus?
    Q.C./Big River
    No, I run them at 150. i dont consider that cold. I know guys that run so cold that their temp gauge never comes up.
    Good point.
    In the world of internal combustion engines, thats still cold when it comes to the heads quench pad.
    El Cajon, Ca.
    At .027 worth of quench, depending on the bore size, skirt design, and how much piston to wall clearance, I'd be looking for where the piston is tapping the head... and possibly "knocking" the carbon off in the quench area.
    Large, inactive chambers and huge piston bumps make for real inefficent burns... hence part of the reason you have to run a shitload of timing advance compared to somethign like an LSx.
    The Bostick®
    Q.C./Big River
    That's the thing there is no carbon on the quench area or a very very little amount. The piston is still clean there. The pistons aren't hitting the heads. When I get the heads back I am going to switch to a bit thicker gasket.
