Tapered collet help
Results 1 to 8 of 8
Tapered collet help
    waterloo
    Default Tapered collet help
    CG500-37, Tapered Collet
    The snap on stud puller is tits. I am sure it is a common collet. Anyone know the number? Meaning R8, R5, etc?
    Wags
    Aug 2011
    placentia,ca
    where are you finding the numbers you are asking about? i didnt see and r8 r5 numbers.
    waterloo
    R8 is a standard industrial collet used in many millinng machines, etc. R5 is shorter I think.
    The numbers are not in the snap on book.
    Wags
    New Jersey
    The Snap-On text says the collets are threaded to grab the studs. The standard industrial collets would not be threaded inside the end that grabs the tool. Would that matter for your purpose?
    Do you have the dimensions of the Snap-On collet? I can compare to collets we have in our machine shop here.
    Doug
    waterloo
    Hmmm... I thoughs some collet series were available threaded. Maybe I am pissing in the wind trying to save 20 bucks.
    Wags
    Jan 2012
    Default Collets
    my snap on has the #A 80 A it will remove or install up to 7\16 has a 1\2 drive 7/8 top May not be what your talking about
    Wags
    I think so. You'd still need the same business on the other end of the collet to tighten it, and I'm not finding any internal threaded collets on the open market.
    Dec 2010
    Sapulpa ok
    Wags
    Hey Hey I know the feelin !!!
