Magnetos & Tachs?
Magnetos & Tachs?
    Senior Member Lildave's Avatar
    Aug 2010
    Bauxite, AR
    Default Magnetos & Tachs?
    From what I understand, magnetos only work in Oklahoma, but I figure Arkansas is close enough.... So maybe I'll get lucky?
    If I install a Mag, what are my options for hooking up a Tach and Rev limiter?
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    if you run a mag, easy wiring and should work just fine (pending on your motor etc)
    running a tach, do able, but it will be tough finding a 5" tach with the famous yellow wire, or you can try running the converter that MSD sells, i know a few guys that have tried it and it either didnt work or didnt read accurately.
    Rev limiter - i have no experience there. I have never ran one with my Mag, i let my impeller do the limiting and out of the hole i just rolled into it so i didnt send it sky high.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by Lildave View Post
    lildave, just for clarification purposes. magnetos -can- work in other places, at least for awile; but they never fail in oklahoma.
    okie, lake Texoma
    Call this guy, He can fix you up with a tach converter THAT WORKS as well as rev limiter, rpm activated switches or what ever. Great guy to work with.
    ETC Rev Limiters
    H8-2-W8
    [email protected] first pass
