What type of "Kill" switch for my Mag
Results 1 to 13 of 13
    MLC - Mid Life Crisis probablecause's Avatar
    North Orange County (Brea)
    Default What type of "Kill" switch for my Mag
    Running a mag now and after the install, I am wondering what type of switch should I use for the on/off (kill). I was told nothing less than 10 gauge wire up to my dash and to the switch.
    Just my opinion, but maybe it's time for the government to take down the bird feeder!
    Quote Originally Posted by Rexone;
    Try to ignore the haters, they are everywhere, just as in life.
    Quote Originally Posted by Pronstar;
    Liberalism: Logic's retarded cousin.
    Gone
    Sparks, Nevada
    To kill a mag all you do is ground the mag. No need for #10 wire. LOL. Wonder where guys come up with shit like that?
    If I am going to run the wire up to my dash, do I need some sort of heavy duty switch, especially since I am going to be grounding it out?
    Gone
    Sparks, Nevada
    Just buy a good quality switch. Rex marine sells them. Also you might consider a mercury type kill switch ....a landline type deal so that if you were to come out of the boat it would ground the mag and kill the engine. In fact that is the only switch I use on my boats.
    Run a wire from the mag terminal (16 gauge is fine) to one side of the kill switch....then for the other terminal run a wire back to a good engine ground.
    http://shopping.rexmar.com/Merchant2...e=killswitches
    switch 368101 is the landline switch.
    you DON't want 301104 as it can be a "shocking" experience with a mag if you happen to touch a terminal.
    Thanks Fiat48. I will also try to avoid coming out of my 21' open bow jet, unless pushed by my wife.
    Gone
    Sparks, Nevada
    Just a note here....when I got my renewal sticker here in Nevada...there was pamplet enclosed that said "ALL" boats had to have "a device that would kill the engine if the driver was ejected from the boat."
    Default 2 types
    There are 2 types of "kill" switches. For a standard ignition that needs 12V to operate the switch circuit is OPEN when uncovered, CLOSED when the cover is put on, thereby supplying 12 V to the coil.......For a mag, the switch is CLOSED when uncovered, and OPEN when covered. As the cover comes off, the switch closes and completes the circuit to ground, killing the engine. Be sure to buy the switch for the MAG, as they are not interchangeable...........MP
    LOUD BOATS SAVE LIVES
    DING DING DING!!! Money pit has it, A mag creates it's own power and the only way to kill it is to ground it. If you think this is wrong then grab hold of the electrode that protrudes into the cap and give it a spin. M
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Wow, the light bulb just came on.......
    Gone
    Sparks, Nevada
    Which is why I gave him the part number of a mag kill switch.
    This is the face you will make after its said and done
    G H E T T O F O E L I F E
    El Cajon, CA.
    Where is the kill switch usually mounted at?
    If it is a race boat, As close to the driver as possible. for a lake boat, that would be at a point where you can operate said switch to kill motor. Mercury switch is great for both but you will need a tether to pop the cap If driver goes for a swim. For electronic ingition use the switch to complete the curcuit. For a mag use the switch to ground the curcuit. ROCKET SCIENCE. M
