Headers vs logs
Results 1 to 14 of 26
Headers vs logs
    Senior Member johnf's Avatar
    Oct 2012
    Default Headers vs logs
    Have a stock 460 was wondering how much more horsepower is running headers than the log-snail set up??? I have the logs would switch if the improvement was substantial. Thanks johnf
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    i have never done a switch, i ran the logs on my covered motor deal, i have heard like 20-30 hp, if its just a play/lake boat, i like the logs, no they dont sound or look as cool, but with logs you dont have to worry about anyone getting burned or keeping them clean, plus you will have to re-route your plumbing a bit. Just my 2 cents
    Default Logs vs headers...
    I seriously doubt you could gain anywhere near the mentioned 20-30 HP by merely switching over to headers. You might see 2-5 HP increase, and that would depend heavily on what else is in you "combination"... You MIGHT see a reduction in power as some combinations work considerably better with the back pressure the wet logs and snails provide.... IMO, you're better off with the wet logs and the safety they provide to your passengers/skiers/tubers.... Not to mention the Noise laws now being enforced just about anywhere you go.... When everything is considered, IMO, a "family type" boat really doesn't need the "bling/noise" factor headers bring.... Believe me, you DO get tired of the noise and always looking out for the noise police.... You can probably gain the same power increase by merely playing with your ignition timing curve, and re jetting the carb to better suit your needs.....
    Ray
    LOUD BOATS SAVE LIVES
    Jan 2011
    Mickleton, New Jersey
    Ray
    not true I,ve seen 35 hp difference on the Dyno from stock manifolds to performance ones , Stainless marine Or Eddie. Marine Style .And i'm sure Headers will do the same. they work. We changed them just to see the difference.
    With a STOCK (as you posted) 460 ford I doubt you would see enough to make it worth it! When you start playing with the engine it might come into play but for know work the carb, ignition and maybe a cam before the header change! I have been there and done that! Without knowing the boat or hull weight it is all precision guess work! good luck! O.G.
    I agree, with a STOCK 460 the gain will be minimal. Nobody ever saw 30-40 HP increase going from stock iron manifolds on a STOCK 460 to headers in a car and gained 40 hp. If they said they did, their lying. And alumn logs flow alot better than stock iron OEM manifolds.
    Throw a cam, manifold, some carburation and compression at it and the gain can be pretty significant. On a stocker, its not much.
    Jan 2011
    I agree, with a STOCK 460 the gain will be minimal. Nobody ever saw 30-40 HP increase going from stock iron manifolds on a STOCK 460 to headers in a car and gained 40 hp. If they said they did, their lying. And alumn logs flow alot better than stock iron OEM manifolds.Throw a cam, manifold, some carburation and compression at it and the gain can be pretty significant. On a stocker, its not much.
    I don't know now much Hp a stock 460 ( I think around 340 hp ) On that maybe 20-25 hp...don't know never dynoed one... but on a chev 454, 420 hp marine engine you will get 35 more hp with a good set of exhaust and rejet the carb. , Now some of this HP could have been to a carb that wasn't jetted properly in the first place, I've seen some nice gains just in the carb being right. But put the motor on the Dyno make a couple of pulls, change the exhaust make a pull and jet the carb make another pull and bam there it is 35 hp. It's not hard to get 20 to 30 Hp out of any engine on a Dyno now that I think about it. I'm not taking about a car engine.
    Quote Originally Posted by jimclauss View Post
    I don't know now much Hp a stock 460 ( I think around 340 hp ) On that maybe 20-25 hp...don't know never dynoed one... but on a chev 454, 420 hp marine engine you will get 35 more hp with a good set of exhaust and rejet the carb. , I've been there and done that. I'm not taking about a car engine.
    I'd be amazed if a set of headers on a STOCK 460 could muster 20HP over logs.
    Jan 2011
    I wouldn't but I'm not a Big block ford guy the only one I know that runs real good is Mike Smith's in Canada, PS 4 widow maker. and that runs on injected alky. He's going to come down to my shop before the lakeland race and we are going to Dyno it it;s been down a little on power all last year going to find where it went. Should make somewhere between 900 and 1000 hp. ( everything in the bottom end is Chev. type parts. Crank, Rods , wrist pin piston etc.)
    All I know is that they don't seem to scrub as much speed off this as you might think. This thing will spank most Ks running around out there. This boat convinced me that you don't have to put up with heat and noise of set of headers to make power.
    If I had a ski flat with rear seats, I wouldn't even consider headers. Wet or dry.
    Isn't the REAL question how much does it effect the acceleration and top speed of the boat? I doubt the speed difference for a stock 460 would about to 2 MPH. In a jet, probably less than that.
    Nechako
    with the crutch on it in a ski boat logs are fine but if your na you don't think lightnings would give you 30 hp on a 650 hp engine?
    Nechako
    kinda jumped in on this one gums flapin, just read the o/p ya on a stock 460 not 30 hp maybe 5or10 . if a guy was workin at tuning it up with cam intake ported heads blahblah i want headers .
    Placentia, CA
    [QUOTE=gn7;1759870]All I know is that they don't seem to scrub as much speed off this as you might think. This thing will spank most Ks running around out there. This boat convinced me that you don't have to put up with heat and noise of set of headers to make power.
    Isn't the REAL question how much does it effect the acceleration and top speed of the boat? I doubt the speed difference for a stock 460 would about to 2 MPH. In a jet, probably less than that.[/QUOTE
    I think that boat of Rick's opened a lot of eyes. Put a set of Banks or PFM logs on it and probably pick up at least another 30-40 hp.
    steveo143 AKA DiMarco 21 II
    Official Test Driver BOOSTPOWER's Avatar
    WORLDWIDE visit BOOSTPOWER.COM
    Blog Entries
    2
    Logs actually work fairly well on moderate performance engines. Here is a twin turbo motor with logs. 👍Name:  ImageUploadedByTapatalk1356090389.367079.jpg
    Sent from My Boostpower Marine Efi Beacon.
