torque value
Results 1 to 13 of 13
torque value
    Diamond Bar, Big River
    Post torque value
    A little off the boat topic but it does pull my boat so.... anyone have a good recommendation of how to use my 250 lb/ft. click type torque wrench to accurately torque my h.balancer on my duramax to 267 lb/ft.? I have to replace the water pump and this is a req. step in the process. I've called the parts stores, rental yards etc. and the ones with rental/loaner programs only go up to 250# as well. I've considered 250# w /blue loctite but don't want to make it to difficult to remove next time around as it seems this is one of those 100k =/- maintenance issues. I'm just as concerned with over torque'g with my 3/4" drive breaker bar I will be using to remove it.
    warren
    waterloo
    Just set it to 250 and use the torque wrench like many folks do. HAHAHA
    250 is close enough.
    The wp change blows.
    I think I jammed a screwdriver or prybar in the trans/ flywheel inspection plate to keep the engine from turning.
    Good luck.
    Wags
    Senior Member Smallblocksperry's Avatar
    Jul 2011
    Good luck.
    Wags
    i did the same thing, 1/2" extension wedged in between the tourque converter, than used my 1/2" digiital snap on POS tourque wrench until it maxed out, than a cunt hair more
    hope you changed the oring and the little 3" bypass hose while you were in there.
    Member HotRodLs2's Avatar
    Feb 2011
    The rental stores have torque multipliers or if you have a buddy at a heavy equiptment shop ask him if he has one available. Do the job right, otherwise you could do damage.
    Post
    Good luck.
    Wags
    Thanks Wags. after reading all the threads on here about how critical torque accuracy is I guess I'm a little over cautious. Seems kinda silly that a bbc balancer bolt is torqued to what 90ish lb. and spins approx. twice the rpm or more, yet the dmax balancer torque is 268 lb/ft, go figure. Maybe it has to do with the rotating mass? idk.
    Post
    Quote Originally Posted by Smallblocksperry View Post
    Yep, replacing everything that is a maintenance issue while I'm in there. I hope to not have to work on this for another 130k miles. thanks.
    Post
    Quote Originally Posted by HotRodLs2 View Post
    Thanks, I'll call the rental shops and see what they have available. ToolTopia.com has really good prices on torque wrenches and stuff but still a little spendy for me at this time of the year.
    waterloo
    You are missing 17#. That is less than 5% difference. Now, what lube were they specing that 267 with.
    The Dmax balancer is not a press fit, it is a slip fit, hence the big torque value to hold it in place.
    Plus the beating of the diesel cycle is harder than a std. bbc.
    Wags
    I probably cranked my wrench down an extra 10 past the 250. Don't remember. It will be fine. Remember GM union guys put it together the first time. ROFL.
    Senior Member bp298's Avatar
    LHC
    dam, and here i thot joe isuzu glued it together the first time... wags the bubble buster...
    Close to the water...
    Default Torque multiplier
    I work on a lot of heavy equipment in the field
    I have a couple snap-on torque multipliers to get mechanical advantage in tight spots and torque larger #s accurately using a 1/2 torque wrench
    It has a 1/2 inch sq input and a 3/4 sq inch output in a 4-1 gear reduction head
    the set up looks like a torque wrench plugged in a torque wrench you end up with two handles. Bar the multiplier and pull the torque wrench to tighten
    I use it a lot re-torquing suspension U bolts for strech, on big rigs and pinion nuts on trans and rear ends 500 to 900 #s
    Sacramento area
    Set it to 230# pull it mark it. Loosen. Set it to 250# pull it mark it. Loosen it set it to 250# pull it and add the distance between 230 and 250#. Bysides a rental torque multiplyer I would not trust a rental torque wrench
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    I would be leery of the accuracy of the 250 lb setting on that torque wrench. A snap On repair guy told me that the torque wrenches are the most accurate in the mid ranges of their values. They aren't as near accurate on the extremes of the values. Don't know if he was full of BS or not. I would recommend finding a 300/350 +- Ft Lb wrench .
    Steve
    waterloo
    Quote Originally Posted by Roaddogg 4040 View Post
    Steve
    I have also been told most accurate in the middle of range. With that being said.....all the OP needs to do is make sure it is tight enough so the balancer does not "rattle" on the crankshaft. Again, these balancers are a slip fit, NOT a press fit.... hence the huge torque.
    Tighten the MF to 250, click, a little extra. Sleep well.
    Wags
