high speed bypass
Results 1 to 14 of 31
high speed bypass
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default high speed bypass
    When dealing with mech. Inj. And tuning for changes in DA what is the correct way to keep all equal with the high speed with the change in system pressure? Do you change bypass pressure or can the same thing be accomplished with a change in pill size in the bypass.
    waterloo
    Drag app? or just out lake running?
    Wags
    Nov 2008
    Kingsburg,CA
    For now just the lake but going to be drag racing as soon as I can find some fabric to make my pockets a little deeper
    waterloo
    How much of a change in DA? Several thousand feet, or minor stuff?
    Wags
    Nov 2008
    Kingsburg,CA
    Over the course of a season a couple thou. wouldn't surprise me. Looking like a 10-12 psi change +/- from base line
    Senior Member Racer J's Avatar
    Visalia CA
    For lake use I would look for a bypass that doesn't use a pill. I would try one that regulates how much it passes by pump pressure, that way if you are cruising around just past your pop off pressure you won't lean the thing out by passing a (set) pill size.
    Dec 2010
    Sapulpa ok
    Have your pump flowed and buy a tune up. Fuel Injection Enterprises.
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by steele211 View Post
    gas or alky? and with the high speed you change the presure that it by passes at. after you change the main pill
    Nov 2008
    Kingsburg,CA
    Alky. Does it change based on pressure change like 1-1 or is it like everything else and not that easy
    Dec 2010
    Sapulpa ok
    Not that easy. You change the high speed jet or spring psi, it changes everything. You change the high speed pill the nozzle jets/ports ect need changed to keep the system psi where it should be to keep the fuel curve where it should be.
    Jan 2011
    alky is not near as hard as a gas engine but it's not that easy either. you can use the same nozzles but the fuel psi and curve has to be changed.
    There's HP to be had with a high speed to be sure. That said, for what you're doing, I wouldn't even bother running a high speed. We started with a high speed, port nozzels, pump loop and the combinatin was a PITA. It made good HP, but we were always chasing something. At the suggestion of and with the help of Fiat 48, we pulled everything off, went to a smaller pump, everything through the hat and worked with our nozzles until we had a reasonable main jet. One return line, no pump loop, no high speed. Super simple, very consistant, easy to live with and easily ran 7.70 @ 140 in a heavy flat. You wanted to go faster, put a bit more blower to it. Air got bad, drop the pill a couple #'s... In a fast bracket or lake deal, I wouldn't run anything more than that... Good luck.
    Nov 2008
    Kingsburg,CA
    Maybe this is what I should be asking... Is there a fuel psi that I should be working toward or trying to maintain?
    Jan 2011
    I agree with a blower motor it is not necessary
