Ring Gap?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
Ring Gap?
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default Ring Gap?
    I'm going to be ordering and building a Dart 540 shortblock. Finish bore will be 4.501 and using SRP Pistons. Compression ratio will be around 10.5:1
    Question is: What formula should I use for ring gap?
    The motor is going in a jet that will see a constant cold water supply.
    Quote Originally Posted by XClutchboy725 View Post
    I use .0045 X BORE for everything, may be a little big for a N/A, but it allows you to throw some NOS at it later
    Newton Ks.
    That ballparks to .020", and that should be just fine.
    H.L. Mencken
    alot of it has to do with where the piston company puts the top ring, and the material of the piston. SRP 10 1/2 are 4032 with the ring a little ways down and I have had no problems with .0045. JE's 2618 and USUALLY have the ring a little higher and may need .0050. Kieth Black (FORGED) are 2618 but have the top ring way down and have run them as tight as .004 with no problems. If you are spraying NOS and a JE 2618 you may very well have to go to .0052 Coating the tops of the pistons also allows you close the gaps a wee bit.
    Also, the latest thinking with ring gaps is to open the second ring a couple thousands more than the top ring. This helps to keep pressure from building up between the rings and unseating the top ring.
    Alta Loma, CA
    Thanks guys, that helps. SRP is all over the board on their website...
    http://www.jepistons.com/dept/tech/d...instrc4032.pdf
    Hey X, Rule of thumb IS .004 per inch of bore. Just do the math. M
    arron, you better keep your nitrous turned down low if that's your gaps i think i ended up at 35 top and 26 on the 2nd ring, using je nitrous rings.
    Mohave Valley/Quartzsite
    GN7, Oh, I didn't think it was necessary!! I have a tendency to chyme in when I shouldn't. I'm just a rookie in this business and still learning!!
    I'm not sure what you caught of it but I was talking with the main machinist at Eaton's this weekend and he said a cylinder showed signs of end gaps to tight. It's interesting because we've always ran them about .020" or so with these big bores. Not sure if switching from external cooling to internal would change that much but it may have!! He said (Total Seal agrees) he recommends opening them up to .024". He also mentioned that they haven't seen hardly any change from .024" to .030" so I'm going to open them up a bit when I reassemble the motor. I know that I had to much timing in it and it showed signs of pre-ignition on the piston which will show the same scoring on the wall as tight end gaps, for the most part. We knew it may hurt the motor but we didn't have enough time to change props. Lesson learned!!! Sad thing is I ended loosing a lifter bore so my weekend was over anyways!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Just my personal opinion, but;
    A little looser is always better than tighter. Boats run more cylinder to piston clearance because of the cool water not allowing the block to grow like in an automobile application. You need to adjust the rings a wee bit as the standard gap is set for the bore a touch larger than you will see pulling in cold lake water. And I am a big fan of cutting the second ring 4-6 thou larger to keep away from top ring flutter. Also, you failed to tell us of the fuel. I am guessing gasoline?
    Steady Rollin
    Corona
    What kind of gaps would you be looking at with a run of the mill high 400 low 500 cube supercharged lake motor? Sub 12 lbs of boost on maybe 8.5 cr
    Wannabe, that's what's interesting because I actually went the other way, now I'm running a closed system. Regardless I'm going to make some adjustments!! Can't imagine this thing on all eight!! Not sure if your referring to me about the fuel usage but ya Gasoline.
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    I can GAR-ON-TEE that if you gap them at that and hit the sneeze for any period of time you will not only butt the rings, but may actually wedge them in the bore and tear the piston apart. Seen it, not pretty.
    Newton Ks.
    She's plenty happy on Speed Pro Molly. LMAO.
    I don't run big Nitrous like you do, only 150HP max.
    Cast pistons.
    H.L. Mencken
