[Question] blower carbs
Results 1 to 9 of 9
blower carbs
    Mar 2011
    Default blower carbs
    i'm thinking about setting up a blower for my engine, can you convert non blower holley carbs? how much of a pain in the ass is it to tune them. i've set up tunnel ram carbs before. what size carbs for a gas 496 with a 1271, its a lake boat not for racing ?
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by hemdog View Post
    yes, put it on a dyno, size ? need more info
    Yes. Like jimclauss posted, you need to have the carb MODEL NUMBER not just the carb size. Thats means almost nothing, specially when talking dominators. The planned boost/blower drive ratio, and engine specs like cam, heads, compression if possible.
    What type of boat and what its primary use is.
    Mar 2011
    its a sanger pickel fork, just gonna use it on the lake. i have a set of square port closed chamber heads with a lot of work done to them, was told they were done by scott shafroff back in the day. wont run too much boost 5-6 lbs. this is new ground for me, only ran tunnel rams and that was back in the late 70s,early 80s. anybody ever hear of "island porting service" in broad channel ny? i used to work there when i was a kid. pete kenny was the owner.
    do you have carbs now that you want to use, or are you looking to buy something that you can tune for a blower? Still no info here.
    Mar 2011
    theres a guy selling 750 center squrters and another selling a pair of 850 doubble pumpers. any of those work?
    Forget the 750 center squiters. The 660s are bad enough.
    The 850s work pretty well. I ran a set with nothing more than 88 jets all around. If you want to run power valves you will need to boost reference them to the manifold. Not a hard mod, but not all that sure it is alot of benefit. Never did anything for anything I ever ran. If you do alot of slow crusing at low part throttle they can save some fuel. If you do run PVs, then you will need to reduce the primary jetting to around 82-84. Don't bother with a secondary PV. Once you're into the secondaries, the PV would be wide open anyway.
    Mar 2011
    thanks guys for all your help.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Get ahold of these guys and they will set you up with some perfection....
    Nickerson Performance Competition Carburetors, Marine, Automotive, Motorcycle and Personal Watercraft
    The 850s would be a good start. Im running some Nickerson built 850s that were blower carbs, on my T-ram and they fixed them up perfectly for me.
