Arabs with turbos
Arabs with turbos
    okie, lake Texoma
    Default Arabs with turbos
    Thought this belonged in the dyno section for some reason. To bad those 6 cylinders wont work in a jet boat.
    H8-2-W8
    [email protected] first pass
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    It might work Hass.If you have their $$
    I traded for a lightweight hydro. You come up with a 6 cyl turbo and we will take it racing.
    QE 439 Twin Turbo
    Senior Member snoopjonnyjon's Avatar
    Saskatoon, Sk, Can.
    Not an air filter in sight...
    Maybe the turbos run hot enough that it just melts the sand it is injesting, and then coats everything with it... like a ceramic coating!
    Senior Member bp298's Avatar
    LHC
    hey shiek hass. looks like you infringed on their copyrights one too many times
