High Rise Manifold
Results 1 to 5 of 5
High Rise Manifold
    Senior Member SBS933's Avatar
    Jun 2012
    Default High Rise Manifold
    What advantage, if any would there be in running a high rise Edelbrock manifold on a basically stock 454 BBC ? It would be replacing an Edelbrock Torquer 2
    Senior Member overpriced hallett's Avatar
    A loss of power
    May 2012
    Everything I have read is the edelbrock rpm airgap beats the torker 2. Hotrod has a test
    Intakes, Carburetors, Carb Spacer - Best Induction Combo - Hot Rod
    1990 ultra 21' open bow. 509, American turbine Jet
    Quote Originally Posted by SBS933 View Post
    If you have one, it would only cost the price of a set of intake gaskets and some time to check it out. If not,, I don't know that I would suggest buying one for the rather small gain it may give you.
    Jun 2012
    Thanks for the input. I do have one available, but I am happy with what I have. I was told I should run the High Rise, but I know that just bolting something on can rob you or do nothing. Thanks Again.
