Procharger twin intercooler for BBC
Results 1 to 12 of 12
    Lake Cruiser, Wave Maker
    Default Procharger twin intercooler for BBC
    I wanted to know if anyone has run the procharger twin set up on their Boats for a supercharger or Turbo application.
    I have twin 76mm's on my 540BBC and am running a sheet metal intercooler mounted to the side of my engine that is not very efficient. I saw on Prochargers website that they offer this for a street car application so I called them and they said they have sold a few for people using them on boating applications.
    Any advise would be helpful.
    Aaron
    Here is a picture of the set up now...
Name:	boat turbo pic.jpg
    Is this intercooler air to water or air to air.
    I have the AW504 which is the largest air to water they make.
    I would have to believe the air to water would be more efficient.
    Air to Air
    check out their air to water units, small and compact compared to air 2 air.
    plus your pumping cool lake water thru them which would bring you IAT's down.
    I have found the Procharger tech line knows very little about Marine applications.
    Can you give me some info on the air to water...like where I could one from?
    Also what part of NM R U
    sent you a private message
    Sep 2009
    Default There's an AW504 in classified's for $850
    WV
    Check Ebay for intercooler, also another key word is Treadstone.
    spokane, WA
    You need an air to water bad man!!! I ran a precision turbo PT2000 on my last kit on my jet boat with a pair of S475'S (75mm wheels) with 16 psi on 92 pump gas!!
    Another awesome place is Robert at CHISELED PERFORMANCE!! His website is http://www.chiseledperformance.net/ he is usually 3 weeks out but well worth the wait and can build you any size and configuration you want/need!!
    As much as you have in your set up spend the money and buy a quality air to water from Robert or Precision!! It will make a night and day difference in your set up!!
    Travis
    cb1
    cb1 is offline
    is the exhaust water cooled in any way? what kind of under hatch temps are you seeing
    Diesel Pimp WINspeed's Avatar
    Aug 2009
    East Bay, ca
    Quote Originally Posted by 358ciHD View Post
    Check out Bell Intercoolers. They are the only ones we found to hold up under real high boost(100+psi.) Maybe over kill for a gas motor, but they are super high quality. Call them and they will custom design one matched to your combo.
