something a little different
Results 1 to 11 of 11
    Senior Member LOLYFE's Avatar
    Idaho
    Default something a little different
    Here are a couple of pics of pop's new street rod motor, just about ready for dyno. This part of the build has taken just about a year to get all of these components together and assembled. Dave Braswell did these carbs himself and are much different than the normal split dominators, smaller and setup progressively for good street manners. 604 ci, Donovan block, afr 385's jesel valve train and lifters, Marcella intake, custom Schwartz offset drive msd distributor and all other type of goodies.
    Its going in a 40 's era Cadillac convertible, so we thought that a six pac set up would give kind of an old schooly look, but with a modern hi tech twist. Car will be done in early march, Will post some photos when completed! No, those are not the valve covers being used
ID:	196106   Click image for larger version.
    Derby, Kansas
    Thumbs up
    Quote Originally Posted by LOLYFE View Post
    Very cool looking engine, thanks for posting.
    Senior Member snoopjonnyjon's Avatar
    Saskatoon, Sk, Can.
    Wow, the tri-power dominators look sweet.
    okie, lake Texoma
    Freakin Nice$.
    H8-2-W8
    [email protected] first pass
    Really cool! Marcella's intakes are all a work of art. Dave Braswell...well, what can you say about him except carb genius.
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    That looks great on that manifold. Im anxious to see what the numbers are after the dyno session.
    Here is something a little different too!
    Its a mid 50s caddy engine that my dad is putting together for a 36 Auburn boatial speedster. No speed equip newer than 1960 were his rules! Kinda the opposite of your pops engine! 6 deuces, mag Ign, log intake clear red wires and more stuff that im not old enough to have seen new!
    Thats a great look,hate to see a nice mill made just for street duty,post the dyno pull if you can.
    Idaho
    Finished up motor and dynod, 930 @6500 conditions were not the best, 91 octane pump gas, finally ready to go into car, pic is of the Schwartz offset msd distributor
    WV
    Any chance you would share camshaft numbers on that and static compression ration, Thx. Great numbers.
    Idaho
    compression 10-1 789 in 722 ex, 296 in, 305 ex 114 center, heads have had more work done to them than what afr delivers, rocker arm ratios- cannot divulge that info
    Very nice and Sano!
