cylinder head swap
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 52
cylinder head swap
    Senior Member motor head's Avatar
    Jan 2011
    Default cylinder head swap
    Have any of you ever changed nothing but heads or heads and cam on a motor and get an increase In rpm with the same impeller? In a jet boat.
    [SIGPIC]
    Member 1980condor460's Avatar
    Newcastle
    Default Great Question
    More info is needed.... a change in the heads would change the complete set up from compression to the amount of air the engine will pump. My guess is that peeps will need to know specifics as to what heads and cam you currently have to what you are thinking about changing to.
    Jan 2011
    Yes I know all that comes Into play. I guess what I'm saying is will more cfm (only) which is more hp, turn the same impeller more rpm. And I'm talkin from 320cfm to 360cfm
    [SIGPIC]
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    Quote Originally Posted by motor head View Post
    I thought I was going to be a wise guy and put aluminum heads/ roller rockers and new intake and carb on my stock 7.4l in the Baja. Engine lasted about 15 minutes. Rebuilt it with new cam and it lasted another 7 minutes.
    Then took it to Moritz and they fixed me up.
    Jan 2011
    I will use same cam and everything I'm running now. It's plenty big! My heads just suck! They flow 298 cfm @25" so whatever that is @28" that everything is advertised at. But if I'm going to have to put a smaller impeller In and turn more rpm to really utilize the hp gain then I'll keep it as is for now.
    [SIGPIC]
    Why does everybody assume that more CFM equals more power. Most, but not all, have learned in time that a 1250 dominator will not make more power on a stock 350 over a 750DP. But bring up the topic of heads and CFM automatically means more power.
    If you said more CFM from a port the same size, or the same port buy just cleaned up, I would be more inclined to say yes, there would be a gain. But a larger port to get the extra CFM, more than likely NO. You could possibly lose, specially below redline. Without the addition of a matched cam, the extra port volume is definitely a loser.
    Like Condor posted, not enough info.
    Jan 2011
    Ok I get all that. I'm talking about swapping my ported pro crap heads for some trickflow 290 street strips. The port should be close to the same size. This is on a 557ci. Mota
    What is 298cfm @25" be @28"?
    [SIGPIC]
    Tower Park Resort, Lodi, CA
    Short answer is yes.
    Long answer is more involved and varies. See GN7's post above.
    The best gain to be had is in improving the single most limiting factor. Once everything is optimized for your application, you're left with increasing displacement or supercharging.
    Are your heads your most limiting factor? Really not enough info to tell at this point.
    Jan 2011
    557ci, 1050 Dom, 10.5:1comp, pro comp heads. I understand motors just maybe not as well as y'all....I just don't totally understand jet pumps yet lol. If you go by an impeller chart if you pickup more hp @ more rpm then you should turn more with the same impeller but iv learned the hard way that torque is the biggest factor.
    [SIGPIC]
    Is this BBF?
    Jan 2011
    When I hurt my 472ci motor all I changed was stroke and cam picked up 500rpm. Same compression even.
    [SIGPIC]
    Jan 2011
    Is this BBF?
    Yes sir
    [SIGPIC]
    This is the multipler chart.
    So a port that port that flows [email protected] 25" would flow 315
    Jan 2011
    Lol!! See THEY SUCK!!!!! and they are on a 557!
    [SIGPIC]
