Port Finish
Results 1 to 14 of 33
Port Finish
    waterloo
    Default Port Finish
    How to?
    OK, I have seen a lot of beautiful port work in my day. I am not a porter. Don't wanna be.
    I do, however, want to be able to duplicate that beaufitul finish I see. Straight, smooth lines...
    What do you guys finish with? Just a sanding cartrige?
    A flapper wheel? WTF
    Wags
    waterloo
    No, these lines.
ID:	197401   Click image for larger version.
    No, these lines.
    Those are probably done with a flapper, although there are some guys who go way crazy with their finishes and have some secrets. I use a combination of cartridge rolls and flappers for my finsh work, but lately I've been finisheing some stuff with the carbide burr and leaving it. There are areas in the port where this can be worth a little extra power.
    waterloo
    Flapper? WTF is a flapper?
    I'll google it.
    I can't seem to get it so pretty with just a cartrige roll. Maybe I am just lame. HAHA
    Thanks Scott.
    Wags
    waterloo
    One of these? Seems like they would be "hard".??
    Nah. They also make them with scotchbrite between the layers, or just pure scotchbrite.
    plus crossbuffs
    and then there is the age old trick of slotting a piece of 1/4 rod and putting 2 layers of emory thru it and creating a butterfly flapper.
    plus crossbuffs
    Bingo. This is what most guys do that I know of.
    Wags, get a piece of 1/4" round stock and slot the end of it with a hack saw, 'bout an inch deep. Then go get some 1" wide roll emery cloth. I use 40g to finish intake ports, 100g to finish the ex ports. You tear a strip about 6-8" long, slip one end in the slot, and roll it up. Then you use that to "flap" the ports. If I can remember tomorrow, I'll try to get a pic or two.
    plumbing supply houses sell stuff that they use for sanding copper pipe for sweating that works pretty good. The blue stuff seems to work and last the best. And its already in a roll 1" wide.
    Atlanta, Texas, United States
    AS per Steel, the emery tool on the left will flapper out pretty shiny. A shiny port sells.... but as per Steel is not always the best air flow. If an intake port is too slick you will loose your boundary layer and the air/fuel will begin to stick to the port wall. One can see this at times if you pull the intake off, the port is real shiny and has fuel stain streaks down the ports. If you see this the fuel has fallen out of suspension and more than likely there is a power loss. Another tool that sometimes helps straighten out your port wall is a long tapered stone. The stone can take some of the cuts and chatter out of the finish left by a grabbing carbide. The stone finish flows pretty well and can then be easily polished with an emory roll.
    waterloo
    Sweet. I will make a flapper mandrel. Do you guys like the cross buffs? I'll try some.
    I only port match and bowl blend.
    Real race stuff goes out to real porters. I do not have the desire, time, or knowledge.
    So, it just needs to look sweet (ok, it needs to be right and look sweet)
    Wags
    Quote Originally Posted by Gearhead View Post
    Wags
    Hey Wags, show us some pics of what'cher workin on.
    Cross buff? Do you use that in the shower?
    waterloo
    Funny stuff...
    I am getting myself psyched up to start on a set of 781's and a set of alum wal mart brand SBC heads.
    I really don't like to port. I'd rather bore a 4.250 bowtie block to 4.600.... it is just as boring. (but with boring I can surf the net or something)
    Wags
    I'll post a pic or two when I really start. You probably will learn something.... ROFL... HAHAHAH
    Wags
