1,700 HP Stock head 429 In. Ford ! !
Results 1 to 14 of 17
    Default 1,700 HP Stock head 429 In. Ford ! !
    Wow I think I could use one of these:
    What 40 psi and Alky can do for you
    Sleeper CP
    Big Inch Ford Lover
    Cantard 71hallett's Avatar
    snow bank
    I love the way antifreeze pisses out of those fords. lol Awesome video though.
    You'd more than likely piss too if someone pumped 40 psi into you
    Come to find out it's oil. There is no water running in the block or heads.
    Sleeper CP
    snow bank
    Sleeper CP
    40 is LOTS, we might end upat 30 next weekend on a chassis dyno, see what happens. Open house at a shop up here with a chassis dyno and we hold the #, from last year. Another guy is comming to try and beat it so we are just going to lay down 200hp more than him whatever the # comes in at. Blow through 400 sbc with twins.
    The Grand Wizard dmontzsta's Avatar
    SoCal
    That is earth shaking power.
    I wake up and I piss excellence.
    Quote Originally Posted by dmontzsta View Post
    Here's some info on it:
    http://www.460ford.com/viewtopic.php...87cbb6734f8968
    Sleeper CP
    let's hear about that sbc400 ! i've got a nice 400 i'm die'n to boost up and put some nitrous on.
    cfm
    cfm is offline
    Dart block I'm hoping.
    snow bank
    Yup calies crank, eagle rods, diamond pistons afr heads. twin 70mm makes 1000 real hp on pump gas 15lbs boost. Goin to add c16 on sat.
    cfm
    cfm is offline
    Schweet ! Afr 210's or 227's maybe ?
    cfm
    cfm is offline
    Heh Sleeper and others, sorry to sidetrack a little, but it does involve twin turbo's.
    Have you seen this maniac ?
    Or this Steve Morris carb'd 509 ?
    snow bank
    Didnt know if anyone realy cared. They are actualy brodix 227 ported by Keith Craft. Was just trying to make it easy.
    San Francisco Bay Area
    Cool
    The engine is using a factory iron 4-bolt block, factory iron Cobra Jet heads, and the factory cast 429 crank. Still, it says a lot about the strength and capability of these Ford 385 Series powerplants, even in factory issue trim.
    Erica Ortiz recently ran a 6.88 @ 205 mph in the quarter mile with a similar setup: a twin turboed 500-inch factory iron 4-bolt block, factory iron Cobra Jet heads, and the factory cast crankshaft. This engine was built by Mr. Moody himself; in other words, built by a racer who has been racing since long before 4-bolt blocks, aluminum heads, forged cranks, etc., were regularly available and the primary factor (other than the stout 460 engine parts themselves) was knowing how to work with what was available at the time and make these engines perform at a very impressive level.
    My own business partner, Van, managed 7.20's with factory iron 2-bolt block, factory iron passenger car heads, and the factory cast 460 crank. That was with the blower set dead-slow at 7% overdriven; if he changed the top pulley to one less tooth, the engine destroyed parts behind it...usually the TH400 Halibrand input shaft.
    LO
    High Flow Dynamics
    snow bank
    Well it looks like tomorrow we set the new record. Guy just made 814 at the wheels with his big block ford on the bottle (350 shot) Oh well........ 20lbs and c16 should give us about a 200hp window. Just a little small block and a couple turbo,s that fell of a dodge truck.
