another cam selection question
Results 1 to 6 of 6
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    Default another cam selection question
    I/OB low hr stock internal 454 mag with rectangle port heads(heads were refreshed 2 yrs ago they added hyd roller rockers), emi thunder headers w/risers,edl air gap intake with Holley hp750 carb,with a water pump bypass. what are some of my nice options to for a cam/lifter/ swap with out possibly running in to the water revisions area and not being to radical
    I call it the brain tube, I've been telling her the more time she spends on it, the smarter it's going to make her.
    Tower Park Resort, Lodi, CA
    What RPM are you currently running at wide open throttle?
    And I assume you mean you added roller rockers, not a hydraulic roller cam. Correct?
    Any idea what your compression ratio is?
    vallejo,cali
    rpms all depend on what prop i got on there,right now i got the 24p 4 blade and it turns 4800rpm @ almost 69-70mph on the dash that's stick down n aired out.
    yeah just roller rockers still stock cam, working on getting the true engine internal specs, a lot of mixed info on line!
    Senior Member h2oracer's Avatar
    PM sent
    vallejo,cali
    Quote Originally Posted by h2oracer View Post
    PM sent
    got both pm's thanks sir for the input...
    vallejo,cali
    Still looking for the stock info on the motor, 454 magnum rectangular ports came stock with a 4 barrel holley and the winters gm aluminum intake
