Valve settings ...
Results 1 to 14 of 16
Valve settings ...
    Oct 2010
    Lake Dallas TX
    Default Valve settings ...
    Just need a baseline to start... 580-610 lift solid flat tappet crane gold 1.7 rockers. Don't want to pull engine to get numbers off the cam (if it even has any) checked them while repairing other custom parts (see below) intakes went from 10-21 exhaust more consistent at 21-23 I'm thinking 16 intake 22 exhaust comments welcome I'm an Oldsmobile guy not used to these fancy parts in BBC
    Nov 2009
    Jerome, Idaho
    Intake .018 to .024, Exhaust .020 to .028
    Quote Originally Posted by hellnback View Post
    I would make note of the tight ones, and make sure to check them the next time you run it.
    My own personal guess on an unknown solid flat tappet setting would be .022"/.024".. .002" extra clearance on the exhaust valves.
    Tower Park Resort, Lodi, CA
    Isn't there a variation of something like 0.002 between iron and aluminum heads... something like that... I forget. Pertinent?
    You might want to do a leak down on the cyl that bent the pushrod just to be safe. you also may want to be sure the flat side of the roller rockers are facing up
    Senior Member sanger448's Avatar
    Apr 2009
    Medford, OR
    When setting cold add .002 for iron block, iron heads
    Subtract .006 for iron block, aluminum heads
    Default Ramp speed....
    Valve "lash" is a recommended setting of the cam manufacturer based on ramp speed... Some cams are slower than others and require less clearance to maintain the designed duration of the camshaft... Others are fast, and require more. An old school idea says that loose lash gives you more bottom end, and tighter lash gives you top end, and additional RPMs. (not a lot, but some).... A mere .002 tighter MAY give you 200 RPM up top by increasing the duration of the "valve event". The lift isn't changed enough to matter.... The .018-.028 settings mentioned are certainly close enough to run with just about any solid grind, and from there some close monitoring and a little experimentation will allow you dial it right in to your application..... If it's a monster down low and noses over up top, try tightening in .002 increments until you balance out your performance for the best of both worlds.... I set valves cold, and if I need to check hot I'm only looking for consistency throughout the valve train...Which will also tell me where, (.xxx), my cold setting is when hot.... IMO, the best thing you can do for a solid cam application is a quality stud girdle to keep things where YOU put them.....
    Ray
    LOUD BOATS SAVE LIVES
    Default Well....
    Quote Originally Posted by sanger448 View Post
    Running a MK IV block, AFR aluminum heads, and a "Bullet/Straub" roller cam, I set the valves @TDC to the recommended clearances cold.... After a few runs for tuning I re checked hot and nothing had changed, well maybe a thou here or there, but nothing that couldn't be related to the new valve train parts finding their "home"..... I'm betting if I set them -.006 there would have a whole bunch too much overlap.....Not to mention the additional duration... Vacuum is a precious thing in a NA application..
    Ray
    Oct 2010
    Lake Dallas TX
    Well I'm going to go ahead and pull it. See if there's any numbers on it. Its only 8 bolts. Should change the oil and flush the sparklies out. Shop owes me a dyno run anyway.
    Apr 2010
    Rocklin, Calif.
    Ray
    I too have set my lash cold..I belive the moter cools faster than I can move
    Joey Grose told me ..solid roller .016 cold int. + ext.
    I do .018 seems to be fine............the jesels dont really move to much
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Mine is a cast iron block, Brodix aluminum heads, comp billet roller, ....... Brodix says to set valves -4 from the .028/.030 advertised I set them at .024/.026 and checked after bring the motor up to 140* ....... they were .028/.030
    Jan 2011
    Mickleton, New Jersey
    .008 difference, your on serious medication.
    Quote Originally Posted by jimclauss View Post
    I don't know Jim. .000 to +.002 with iron heads is not unusual at all, and I subtract .006 my alumn heads. Maybe running gas and longer periods is the reason. All I know is that -.006 works the best for me.
    As for medication, I saw your PS driver tonight. Now thats medicated.
    Apr 2009
    Medford, OR
    Sorry jimbo, but those numbers are not mine. Taken off the Crane Cam website. Guess you better give those guys a call and straighten them out ???
