Mechanical Tach Bounce
Results 1 to 10 of 10
    Coeur d'Alene, Idaho
    Default Mechanical Tach Bounce
    I have a vertex mag with mechanical tach, and at higher rpm I get a big tach needle bounce..Doesn't matter if I'm in rough or smooth water. It's fine at idle and lower rpm..What causes that issue..thanks..
    Most the time it is the cable. You might try taking it apart and clean and lube.
    You mean pull the center drive wire completly out of the cable clean and lube the solid wire and reinstall..also lube with just bearing grease? thanks for the reply..
    Quote Originally Posted by Tittyman View Post
    Never seen one that you could slide the cable out. The drive pieces on the ends are larger than the ID of the jacketing.
    No, you don't grease it. There is an actual cable lube but its not sittting on shelves everywhere. The next best thing to use is a chain lube. You need to take it out and get it stretched out vertically and allow the lube to run into the jacket.
    It MIGHT work, but you may just need a new cable. Any speedo shop can make you one.
    Also, the tack itself could be the problem, but that usually shows up at low RPM.
    I haven't looked at a gear drive tach cable in a bit, but I know Motion Pro makes a cable luber that clamps on one end and allows you to douch all the crap out of motorcycle throttle/clutch cables. After that, a light lubricant like LPS will keep it free. We use it on our dirt bikes all the time. They're cheap so even if you have to modify it to work on a tach cable, you wouldn't be out much. I probably wouldn't suggest a modern chain lube as it congeals like wax in order to stay on the chain. Vince (stix818) uses chain lube on his props and says it stays on after a pass. I haven't tried it, but gonna.
    Jun 2010
    Buy a new Cable ....duh
    Quote Originally Posted by mdsheppie View Post
    If the cable is bad, you don't even have to buy a new one. You just take it to a speedo shop and they can replace the inner cable.
    Yup, that's it. The little holes are the same size as the plastic tubes on aresol cans like brake clean/contact cleaner. For a lube I used a BelRay product that was an all purpose lubricant.
    Oct 2010
    Lake Dallas TX
    My cable wasn't tightened right at the speedo
