header gaskets
Results 1 to 14 of 35
header gaskets
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default header gaskets
    ok what are you using, i bought the fel pro marine gaskets and on the #2 cyl i can see where i blew the gasket out. Is this normal? I can also see other areas where the exhaust is getting by on other cylinders. They are not sealing very well. I'm sure the header flang is probably alittle warped, they headers are 15+ years old.
    El Monte
    Chevy, Ford, Olds ????? Headers or logs? If logs and they are very old they probably could have lost their heat treat at the flange and are warped.
    B & D Marine Performance
    El Monte, Ca.
    Senior Member wajetboy's Avatar
    Auburn, WA
    im using rimflex gaskets they are a crush style, i have never had a leak with them.
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    J&M Speed Center in Riverside had "Bison" header gaskets years ago. I've had them on my boat for years with no issues.
    I can't find much about "Bison" on the internet though...
    Cantard 71hallett's Avatar
    snow bank
    just one word COMETIC
    x2
    058 is offline
    I don't use gaskets....not needed if the surfaces are flat.
    Newton Ks.
    Chevy header gaskets were too small to mate properly to my Lightnings. Blew right arround the ring on at least 5 cylinders.
    Red RTV, let set up about a week, and installed. Works perfectly.
    H.L. Mencken
    Like 058 said where you can see it blowin, is a low spot.,
    Member Speed565's Avatar
    Australia
    The surfaces must be flat.
    On 'open' motors use RTV.
    Enclosed motors I still use a gasket.
    RTV high temp, I now use black, looks better. Never have had a leak in over 15 yrs. of not using gaskets. I have never worried about it setting up for any more than a few hours. It even handles the Nitrous passes just fine.
    Also don't know how much it helps, but I use studs and brass nuts on the exhaust. They don't back off.
    Sleeper CP
    San Clemente, Ca
    They are basset OT headers on a BBC.
    Cometic makes header gaskets? Didnt know that.
    I'm sure the header flange is warped, these headers are 15+ years old.
    Didnt know RTV works for exhaust, seams like the high temps would kill it.
    Permatex "Ultra Black" Hi-Temp silicone gasket maker.
    Sleeper CP
    if they are warped you might want to have them surfaced
