Want to guess my HP?
Results 1 to 14 of 34
    El Cajon, CA.
    Default Want to guess my HP?
    Do you want to take a guess for me on how much HP my engine will make? It won't be run on the dyno so your guess won't be varified.
    468 BBC Mark IV, stock stroke, .060 over, 13.25:1 compression, Pro Comp aluminum 320cc intake runner heads (2.3 intake, 1.88 exhaust), full roller, .714/.714 lift, 272/278 duration at .050, 110 centerline, dry Borla upswept style headers, Mallory mag II, and for now a dual plane intake with a spacer and a 850 Holley.
    Eventually my MFI after it's been professionaly flowed will be used. The guy that built it said about 620 HP with my intake and carb and about 650 HP with my MFI. A different engine builder told me around 750 HP with either intake.
    Anyone want to take a guess?
    Cantard 71hallett's Avatar
    snow bank
    680ish
    Lurker
    NC
    I would be VERY surprised if that engine makes 750hp with that manifold. Especialy with the type of RPM typicaly required to make that type of HP with that small of CI. The cam is pointing to higher rpm also so I would guess the manifold is one of the big killers right now.
    Unported heads???
    My guess, 600-650hp at best depending on dyno/correction factor used.
    Mohave Valley/Quartzsite
    Sounds like a pretty nice combination except for the dual plane manifold!! Choker!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Do you have flow #'s on the heads and what type of dual plane. I hope it is at least an RPM-Air Gap.
    Sleeper CP
    El Cajon, CA.
    Flow Numbers
    Intake Exhaust
    .100 74.3 .100 62
    .200 166.11 .200 118
    .300 245.36 .300 160
    .400 308.05 .400 195
    .500 339.84 .500 229
    .600 360.43 .600 248
    .700 374.31 .700 265
    Intake Runner 320cc
    Exhaust Runner 150cc
    Combustion Chamber 115cc
    The intake is an old C427X Edelbrock, it's a stepping stone until my MFI stack system is flowed ($$$). I'd say the C427X is most similar to a Edelbrock Performer RPM (non-air gap).
    snow bank
    Flow Numbers
    Intake Exhaust
    .100 74.3 .100 62
    Intake Runner 320cc
    I take my 680 back, 650max Put a real intake and a 1050 and I bet you see about 725-740. BTW Wilson has them in stock.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    600hp with that intake,but i bet it will alot of torque and jets like that,nice combo good luck
    With those flow numbers with a Victor Jr. and a 1050 Dominator I would think 730-750 is possible( I'd play it safe and would say 740+/- 10) But with that intake on it I'd say take 60-80 hp off of 740, so maybe 670 and that is on the high side. That manifold is going to want to give up at 5,800-6,000 and the cam is going to want to go to 7,000.
    Be happy if you get 650 out of it with that manifold.
    When will it hit the dyno ?
    Sleeper CP
    snow bank
    Sleeper CP
    st did one with a little more stick in it and it made 750. 1050 and victor intake. Guy wouldnt spring for the wilson but they are normaly good for atleast 15-20
    El Cajon, CA.
    ... When will it hit the dyno ?
    Sleeper CP
    Probably never. I don't know what the current impellor is that's in it but I have a C cut impellor waiting for the project. Maybe the C and a impellor chart will get me a close approximation.
    I know that intake is going to choke the crap out of it, but I'd rather spend the pennies on getting the MFI flowed rather than a better carb/intake setup.
    I should have read the first post twice.... I would have known that.
    But you might want to check at Ed Hale's for the cost of a break in and 4-6 pulls ? I might be worth it.
    Sleeper CP
    snow bank
    Please dont think I am knocking your project. It sould be a fun and happy motor.
    El Cajon, CA.
    Are you kidding me? You guessed 60 more HP than the builder guessed, that ought to be worth at least a beer or two. Allmost free HP. J/K
