Valve stem seals
Results 1 to 6 of 6
Valve stem seals
    Default Valve stem seals
    Can anyone point me in the right direction for valve seals that dont need guide machining, for use with triple springs on a gen iv Chevy? Thanks!
    Quote Originally Posted by Mr Plow View Post
    No such animal.
    You sure they are triple springs and not duals with a damper?
    No such animal.
    No, I was wrong, they are doubles with damper. Are there seals that can be used with those then without interference?
    With a stock 3/8 diameter valve stem and a stock outside diameter spring, not that I know of.
    The cutter for postitive stop teflon "type" seals is about 70.00 and you can do it yourself with a 1/2 drill motor.
    Do the springs you have even fit the stock spring seats in the heads?
    Thats the other thing I need to check today. I May be putting the cart before the horse.
    Redding, CA
    Sounds like you are trying to swap springs without pulling the heads, correct?
    FWIW. I don't even run seals on my ex. valves, and just have all rubber positive push on seals on the intake. (Although I have just ran umbrellas trimmed down to fit in the spring before)
    I don't like Teflon seals at all. Valve stem killers in my book.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
