yet another cam question
Results 1 to 14 of 17
    Surprise, AZ
    Default yet another cam question
    Ok guys, I usually have been running my headers dry but after a season of hard running, the coating is flaking off. I think it is because of getting the headers too hot. Anyway, Jet-hot is going to re coat them at no cost. Now my question is, can I run water to them with my cam?
    Cam specs;
    Advertised
    lift .660 IN, .620 EX
    duration
    298 in, 308 ex
    Gross lift
    .440 in, .414 ex
    Duration @ .050
    264 in, 270 ex
    Am I safe to run water inj. to my headers without issues?
    I have run a lot bigger then that. But need rest of specs to be sure.
    You have run more than 298/308 duration with wet headers and no problems. How much more?
    Surprise, AZ
    106 lsa
    Quote Originally Posted by 67weiman View Post
    106 lsa
    AHHHH. No.
    Surprise, AZ
    Exactly my thoughts but figured I'd ask the experts.
    106 lsa
    run a manual water valve
    what size is the engine?
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Erson Cams made a grind they called "JB200". it had I think 240 degree duration at .050 and a lsa of 108 degrees. I ran it with wet bassetts and had serious milkshake issues.
    Surprise, AZ
    Quote Originally Posted by Sleeper CP:1910314
    106 lsa
    Sbc 377.
    Jan 2011
    Mickleton, New Jersey
    Cam specs;
    Advertised
    duration
    298 in, 308 ex
    Gross lift
    .440 in, .414 ex
    Duration @ .050
    264 in, 270 ex
    NO
    Tri-Cities, TN
    NO.
    that cam on duration sounds HUGE for a 377 unless your turning it 7200 or 7400.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Surprise, AZ
    Quote Originally Posted by cstraub:1923378
    NO.
    Yeah Chris, this motor was intended for a drag car. I know the cam is a little big but untill I can afford to have you make me a new one. I'll run what I got...
    Tri-Cities, TN
    Depending on the heads that thing needs to be in the 240 range.
    Chris Straub
    Straub Technologies
    Surprise, AZ
    I'm running edelbrock performer rpm heads, with some port work done. 11.5-1 static compression. Currently spin a stainless "b" 5500. How much power am I leaving on the table?
