Carb problems
Results 1 to 3 of 3
Carb problems
    Dec 2012
    Default Carb problems
    Laright carb guys i am having a problem i have two 1050s on my 477 in my canyon the motor runs great but when i shut it down its bleeding fuel out of the carbs and filling up number 6 cylinder for some reason they are on a pro dominator holley tunnel ram with a aeromotive a2000 fuel pump. My first guess im thinking maybe a needle seat is leaking by but in not real sure the floats are all good the only other thing i can think is going on is i have a solid driveline in my canyon so i have the motor sitting at the angle of the driveline so the carbs are at a little angle while sitting on the trailer. Do they make a wedge spacer to fix this problem
    Angle is probably not the problem. Nearly all V-Drives have the engine angled when sitting or running.
    I would guess the problem is a needle and seat problem, fuel height adjustment problem or regulator pressure is too high.
    What is the fuel pressure with the motor off. I like 6 3/4 Lb with the motor running, but others may like something else.
    Does the fuel flow out when the motor is idling or after the motor is turned off?
    Dec 2012
    Default carbs
    I have it set at 6 1/2 with a aeromotive return regulator the pump return is blocked off just using the return on the regulator am i supposed to have the return on the pump also, its the aeromotive pump with the regulator built in to it but didnt figure i needed to return fuel in two places
