electric fuel pump help
    Senior Member tx-19's Avatar
    wittmann,az
    Default electric fuel pump help
    Need help figuring out witch one to get for my application.the pump needs to be mounted a little higher then the tanks.the motor made 1050.two dominators asperated.any ideas what would work?
    Dec 2012
    Default fuel pump
    I run a aeromotive a2000 on my motor im making 750 with 300 shot of nitrous and it has been a great pump
    Senior Member MBMoseBilt's Avatar
    Weldon. The next pump I buy will be a Weldon. Aeromotive is a great pump but the will prematurely wear if it has to suck fuel.
    Try to get the pump below the pick so the pump will be syphon fed. This will help with it wearing.
    The Weldon pumps can be mounted in any orientation and above the fuel.
    Check them out.
    Dec 2012
    Default pump
    Guess you have had bad luck with aeromotive but i have been running them for years now with no problems have aeromotive pump on 5 street cars i have built with no issues. I would run a aeromotive pump if it were me they build a nice pump
