Blown Gas to Inj. Alky ??
Results 1 to 14 of 32
    Oct 2011
    Sandia,Tx. 78383
    Default Blown Gas to Inj. Alky ??
    Is it feasable to just pull my gas carbs and bolt on say a alky Birdcatcher setup and use my Elect fuel pump to feed the 80a pump instead of having to install gravity feed tanks ....just thinking out of the box ..I have (2) 250gpm elect pumps that are also alky compatable installed now ...thats why I'm thinking of this scenario
    Albuquerque, NM
    Curious to hear some resonse on this as I was thinking about that very same thing just last week. That is how we modified an old box style bronco to run a EFI 5.0 motor (low pressure pump by the tank to feed the high pressure pump by the fuel rails) and it works well.
    24' Eliminator Fundeck
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    enderle pumps like the gravity to help and his highly recommended, but not always a must, lots of drag cars without complete gravity tanks.....no expert, just my .02.
    what i would do it get u a 3-5 gallon bullet tank, feed it to the 80A, if its a lake/race deal, what we did was fill saddle tanks with alky and used an electric pump to pump into the bullet tank.
    Oct 2011
    Sandia,Tx. 78383
    just figured if I force fed the suction side on the 80a at 4# (?? ) regulated from elect. pump how would the 80a pump know the difference ?? as long as it had a steady un-restricted suppy ?? Would this not be actually better than relying on gravity ?
    Just asking honestly , I have no idea if anyone has tried this in a boat before and yea it would be for lake /sustained run usage
    http://oathkeepers.org
    Led
    Led is offline
    Jul 2010
    an 80a will flow at different GPM, u can try it, but i would set the e-pump regulator at more than 4, to protect lean on the big end, your barrel valve should return extra fuel at lower rpms
    GN should be here any minute, to make it clear as mud.
    a 3-5 gallon bullet tank would only cost a few hundred bucks, think i paid 300 for my 8 gallon and had extra bungs welded in
    Oct 2011
    Sandia,Tx. 78383
    Cool , just know a guy that has an alky hat setup laying around ...and well I was thinkin '
    but when I think it usually gets me in trouble !
    Led
    Led is offline
    Jul 2010
    do it, "borrow" or "try it out"
    Me too, usually not enough thinking (thought) before i an elbow deep or the unusual over thinking and then increases my anxiety....then i have to make 100 phone calls to my guys (info, pisston, bp, etc)
    Oct 2011
    Sandia,Tx. 78383
    any idea on power output on identical setups just going from gas to alky ?? of course this is what has me thinking crazy ideas
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    Going from gas to alky is a night and day difference. I've heard its like the first time you spray with nitrous.
    Albuquerque, NM
    I do kind of like the side tank thing fed by a traditional pump because one of the biggest issue I was having is an 80A-0 pump flows like 4 gpm or 240 gph at 4000 rpm... and to get an eletric pump to keep up with that is not the cheapest thing to do. But like you said as long as you have a return system and put the regulator inline after the -80 pump I don't see why it would not work. The lines would also have to be large enough to handle what the -80 requires, but with pressure on your side that is a plus. Then where would you return the MFI fuel? To the bottom of the -80 pump?
    Albuquerque, NM
    Quote Originally Posted by Gopher711 View Post
    Well identical is not the right word to use here.... Cause you can run way more boost with the Alky, and hence its not identical. What is your CR?
    Dec 2010
    Sapulpa ok
    It could be made to work but it will be hard. The electric pump will seep trough the injection pump at idle/ low rpm.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Bigblockbill View Post
    I've ran 13:1 & 38 psi but the tuning window is small.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by vdrivegrimes View Post
    Yep x2
