Connecting Boost Gauge
Results 1 to 7 of 7
    Silverdale, Washington
    Default Connecting Boost Gauge
    Curious what the masses have used to connect their dash mounted boost gauge to the motor? -4 SS seems overkill, plastic seems underkill.
    Your thoughts would be much appreciated.....john
    Placentia, CA
    Have used both with good results. ss4 just much cleaner.
    steveo143 AKA DiMarco 21 II
    You can use black hose, or I have seen some guys use stainless from the engine, and couple it to black hose under the gunnel where it doesn't show. You can also probably use -3 instead of -4.
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    i use -3 stainless all the way to the gauge, for oil and boost.
    It's not that i don't care, I just dont give a sh!t!
    Appreciate the responses, SS it is..........john
    Wet
    Wet is offline
    East Hampton, CT
    I used a roll of small dia copper tubing. Looks good enough for $15
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Plastic water line for me. I just put black wire loom over it, hides it well.
