Mallory distributor Help ? Feelin Boatlessness
Results 1 to 14 of 15
    Senior Member chrisbsanger's Avatar
    Grass Valley
    Default Mallory distributor Help ? Feelin Boatlessness
    I have a Sanger mini daycruiser with a Ford 460 in it with a Mallory YLM567EV distributor . I'm not getting any spark . I checked the grounds and all the wiring and everthing seem ok . Do the magnetic breakerless ignition modules go bad ? If so how often do you need to replace them ? I'm no motor head and really need some help . Any advice would be great .
    Grass Valley
    Anybody have any ideas ?
    Cantard 71hallett's Avatar
    snow bank
    Yes they can, check and see if it is rusty or has any cracks in it. I am guessing you have checked for power at the coil?
    Charlotte, NC.
    Here is how i recently solved my mallory problems...
    Runs much better now...
    Grass Valley
    What was your boat running like before ? How much did you need to shell out for that set up ?
    I'm not much of a mallory fan...but they can/do work. Does your set up have a ballast? If it does take a multi meter and check the voltage on both sides. I have a module if ya want one cheap.. If you want to pay shipping there and back I may loan it to ya.
    Grass Valley
    What would you like for it ? Where are you located ?
    Grass Valley
    Quote Originally Posted by chrisbsanger View Post
    bump
    El Cajon, CA.
    That red is difficult for me to read.
    The modules in Mallory distributor's do go bad. Years ago I had to replace the module in my Mallory several times until I got tired of replacing it and I got rid of the Maollory all together.
    Grass Valley
    Can you tell me what it was like when your module went bad . Was your motor running differant or did it just stop working . What did you replace it with ? Thanks
    I could very possibly be wrong, but I thought they either work or they don't.
    mofo has got it they work or the don't. Tester and time will tell. 90% of the time it is either power feed failure or bad module. M
    Grass Valley
    Anybody have one go bad ? Do they just go out ?
    Placentia, CA
    Yes, ran great all day next day nothing. To the trash can and mag installed, no problem.
    steveo143 AKA DiMarco 21 II
