Edelbrock TR 2X
Results 1 to 10 of 10
Edelbrock TR 2X
    Abnormal Member FLATMVN's Avatar
    Blythe, CA / Burley, ID
    Default Edelbrock TR 2X
    Hey Guys need a little help here. I have a buddy that is putting a Edelbrock TR2X tunnel ram on his BBC. The manifold has the bolt holes drilled for inline carbs. Problem is that the Holley 850 Double Pumpers That he has won't fit inline on the manifold and you can't turn them sideways because there is no bolt pattern for that. There is no way to re-drill the top to make a sideways mount bolt pattern. Any Ideas on adapters or what carbs he needs to make things work. Need to stay with the 850 cfm carbs so 660 center squirters are out.
    I suggested double sided tape, epoxy or welding the carbs to the manifold, buddy doesn't think any of those suggestions are viable.
    Iuka, Mississippi 38852
    Louis, i`m running the same intake. he`ll have to change the float bowls to run those carbs.
    Quote Originally Posted by FLATMVN View Post
    I like your ideas, but how about another intake??
    Edelbrock part # 2694 is an adapter to mount carbs sideways on a tunnel ram, they come as a pair when ordering.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Gone
    Sparks, Nevada
    Must be an adapter plate. I have seen sideways carbs on them....fact a local guy's deal is set up that way.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I have the same manifold, it has two bolt paterns drilled into the top of it, not sure what the second set is for though because i'm running dual 4150's (660's) inline.
    He had another intake on it and switched to this one. because he likes the mixing chamber on it. So getting him to change it back or to something else is not the direction he wants to go.
    Thanks for the tip on the adapters. That is just what we are looking for.
    Your quite welcome, just went through the same deal trying to mount a couple of DP's on a late model BBC Edelbrock tunnel ram. Those adapters are only a little over a half inch thick, and are made specifically for that application.
    Larry
    62 Bel-Air 409
    2016 Corvette Z51
    Yea read up on them on summit and that was just what we needed.
    Got them ordered today and should be good for the weekend.
    Thanks Again
