Lose distributer on a Vortec 350?
Results 1 to 2 of 2
    Massachusetts
    Default Lose distributer on a Vortec 350?
    As I was replacing the cap and rotor on my carbed Vortec I happened to peer down at the timing cover and notice the built-in crank sensor and got to thinking...GM started with a good idea, but then bailed and still included a distributer with these engines. What is needed to convert it over to all electronic and ditch the distributer? Is there an oil pump drive shaft kit for going distributerless?
    Real Boats Don't Have Propellers!
    -- Rivernut
    No such luck unless u f.a.s.t. c.o.p..gm ditchd the dizzy with the ls motors
