msd wiring ?
Results 1 to 5 of 5
msd wiring ?
    Maple Ridge B.C. Canada
    Default msd wiring ?
    is there anything special about the 2 wire msd harness from 6al to dist. Can I just extend it with regular wire? Thanx
    Yes just use the same gauge wire
    My MSD is mounted under the dash
    #55
    thanx Outlaw
    small word of caution. The wire should be twisted. Don't run it near the alternator, and don't zip tie it to a battery cable. The twist help keeps it from false triggering from induction that can occur if you don't.
    You can buy a 6' extention from Jegs or Summit for about 12.00 with the ends. Pt # 8860
    If you need something longer, you can buy just the ends to make up your own. Pt 8824
    thanks for the advise gn7. I just pulled it out of the harness I was making,past the starter ,then the alt. Glad I asked
