Piston ?
Results 1 to 5 of 5
Piston ?
    Sep 2012
    Default Piston ?
    Is this normal or what is the cause ? The clean section.
    Quote Originally Posted by Bobbylisa View Post
    You're running pig fat. The clean area is from fuel wash. I imagine you know what caused the black.
    Between running rich, and the cooling effects of that, along with it being in a boat, and the added cooling of that, possibly timing that is a little retarded from ideal, flame can also never make it that far back in the quench area before it gets snubbed out.
    Sep 2012
    Thank you.
    Jul 2012
    Thank you.
    Sometimes we see this when you run a 4.500 plus bore combination and you still have a head that is cut for a 4.250 bore. you have to relieve the combustion chamber for the bigger bore, so you get the flame travel to the back side of the piston.
    Nic
    Quote Originally Posted by nicwoods6 View Post
    Nic
    Yeah, you can sometimes tell a 4.5+ bore needs some chamber work when the thing gives up gaining power with timing before it should. It just goes flat before actually starts losing power due to too much lead.
