Thinking blower.
Results 1 to 14 of 14
Thinking blower.
    Tacoma Wa
    Default Thinking blower.
    I am in the midst of building my N/A boat motor and wanted to see what ya'll would run for a cam if a blower were to be added. I have a forged bottom end at 9 to 1 with a set of 990 chevy Square port heads. How much boost and with what kind of cam would you all suggest to run with this setup? Or do you need more information?
    ~Brian
    Wet
    Wet is offline
    East Hampton, CT
    Quote Originally Posted by LuckyDaze View Post
    ~Brian
    9:1 static? Pump gas? 2 pounds boost.
    blown mopar moparjet's Avatar
    manassas,va
    Mine Is 9.1to1 With 6lbs Boost On Pump Gas.. Mopar Might Be Diff. Than Chevy
    throw it in reverse
    Tacoma Wa
    9 to 1 one Static. And I am undecided about pump vs race gas.
    Wet
    Wet is offline
    East Hampton, CT
    Quote Originally Posted by moparjet View Post
    I fired that number off without doing my homework. 9:1 is pretty stout but at 6 pounds, you're still in pump gas range at a final 12.7:1.
    How did you come up with that #. Desk top dyno? 12.7 to 1, pump gas range?
    Cantard 71hallett's Avatar
    snow bank
    x2
    snow bank
    Not poking, just curious.
    manassas,va
    alum. heads and cold water temps help.. never had a problem in 2 years(knock on wood) i think wet got info from bds site
    http://www.blowerdriveservice.com/techcharts.php
    throw it in reverse
    Wet
    Wet is offline
    East Hampton, CT
    Exactly. I was too lazy to look that info up the other night.
    So can you guys run a (pump gas) n/a motor at 12.7 to 1 also? I'm not tryin to be a smart ass ,I just don't get it.
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    I'll say this my fords a 13.8 to one N/A tunnel ram. It ..........runs........... on 91 fine when you kill it every once in a while you get a little dieseling, but but but It really likes 110 leaded from Love's and I know it's easier on the engine.
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Isn't a stock 496HO 9.1 comp. They run those at 6psi with an intercooler. The motors in my boat are 7.5 comp, and I run 10PSI with intercoolers, on
    91 OCT.
    San Diego.
    28ft Sportcat
    With Twins
    AZ, Queen Creek
    if your buildin it for gas with a blower build it below 8 to 1 static comp and you should be ok.
    ___________
