metering block
Results 1 to 6 of 6
metering block
    Senior Member SBS933's Avatar
    Jun 2012
    Default metering block
    Why would someone run a metering block with air screws on the secondaries. And how do you adjust it ?
    Believe Nothing you hear and 1/2 of what you see.
    Quote Originally Posted by SBS933 View Post
    It's called 4 corner idle and you adjust it like the front. It means the secondaries have an idle circuit.
    Jun 2012
    Thanks Steel, that sounds simple enough. Thanks for the answer.
    'Welcome.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    What Sfeelcomp said and they are fuel screws btw
    QE 439 Twin Turbo
    Jun 2012
    Thanks, I gotta remember that.
