781 heads
Results 1 to 14 of 17
781 heads
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default 781 heads
    Whats the going rate for these? Heads are off a running motor, probably could use new valves/springs/etc... They shouldnt have any cracks and are stock.
    El Cajon, CA.
    I have the same heads in (probably) the same condition. I was thinking of around $150 for the pair. ?
    Ladera Ranch
    You can plan on spending close to a thousand dollars to have something like that gone through and made right for a performance application. If you can do the assembly you can save some money but otherwise entry level aluminum heads are worth the cost just for the weight savings alone...
    El Cajon, CA.
    Well there you have it folks.
    San Clemente, Ca
    Found a guy selling a long block for 275 with these heads. Block is std but a 2 bolt... Just wondering if it was worth it.
    [email protected]
    Ohio
    I'd jump on it if it doesn't have a hole in the side of the block. Those 2 bolts are fine for a lake boat even to 500 hp. They can easily be convered to 4 bolt if you want.
    Tim
    San Clemente, Ca
    What i have now is pushing 500hp, i'm looking to go higher, 700 hp range maybe
    Cantard 71hallett's Avatar
    snow bank
    A studded 2 bolt is every bit as strong as a standard 4 bolt.
    Tri-Cities, TN
    I'll disagree. It has been my experience that once you go over 600HP range with a studded 2 bolt block you will run into cap walk. If you take one apart and there is gauling on the foot of the cap and/or register then she has been walking. At this point you need to install 4 bolt caps at least on the 3 center mains. I have run into this a few times but had the chance to see it with incremental HP increase in a pull truck class years ago. As the class implemented rule changes and the power grew we watched as the "limtations" showed up.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    snow bank
    I will agree with you that it also depends on application. On a motor that will load and unload yes. I have also run 700hp on a studded block with a 300 shot of nitrous and had no issues. I did change the bolts every year mind you and I did also pin the caps. But as far as breaking the block no I havent.
    snow bank
    I guess it would also come down to the point that by the time you buy caps, machine the block exc. you are over half way to a dart.
    Tri-Cities, TN
    Agreed and finding a shop to properly do the caps is few and far between.
    Chris Straub
    Straub Technologies
    cfm
    cfm is offline
    I'd buy it in a millisecond. But not for your future power goals.
    San Clemente, Ca
    cfm, where you located, he's local to me.
