049 vs 990
Results 1 to 14 of 83
049 vs 990
    SoCal
    Default 049 vs 990
    Being that I'm on a tight budget, can a good head shop tune a set of 049's to flow close to or as good as 990's?
    [email protected]
    BLOWN GAS FLAT TO THE RAMP
    REST IN PEACE MY FRIEND
    Tri-Cities, TN
    What size is the Mill?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Member biesemeyer's Avatar
    I built 396 11:1 with 049 heads cut for big valves just a little port work for my 18' Biesemeyer flat. it worked ok but just ran out of head. i now have a brand new set of 990's that will be used on my 427.
    if its for your bezer i would run 990's.
    Quote Originally Posted by biesemeyer View Post
    A 396 with a set of 049's did not run out of head- especially with oversized valve and any portwork.
    Quote Originally Posted by "Flat" foot'n View Post
    I can build a set of 049's to make a set of stock 990's look silly. Is that the question, or are you asking if the 049's have the same potential?
    SoCal
    I have a 468, 9.5:1, 049 heads, 114cc chambers, 140lbs spring pressure, clay smith solid lift flat tappet cam (p/n c-306-8-B) , Harlen Sharp roller rockers, Manley rods and LS-7 steel crank, ARP studs.
    Weiand tunnel ram (square port) with 2 Holley 750cfm DP. MSD Pro Billet, blaster coil and the 6al MSD box.
    What I'm curious about is if I can make these heads perform as good as stock 990's on this application.
    I realize my compression is my Achilles heel but I needed to run safely on pump gas. The best rpm I've seen was around 6300rpm. This is going in my Bezer and I have lightened 18's in the box.
    Initial build was with a Dart single plane with a Holley 850. Considering going back to a single carb set up.
    Would I be better off spending the $ on a set of 990's or tuning and tweaking these 049's? I have another set of virgin 049's sitting in the garage I could use or trade both sets off for 990's. Hell, I don't know. I just want more rpm. I was told these little Bezers like a lot of rpm.
    [email protected]
    Dec 2009
    Northern Indiana
    Were all of the engine specs the same with the single carb set up? What was the maximum Rpm with the single carb?
    The 049's would be a better choice, even with the mis-matched Weiand TR.
    SoCal
    Yes it was. The rpm I can't cant really say, I'm thinking it was around 6000. The tunnel ram really made the boat feel faster. The boat was my Barron Sprint.
    [email protected]
    SoCal
    049's? So what am I going to want done? Are you local to SoCal? I'll be pulling the motor down to key the crank. I'd like to make the changes then.
    [email protected]
    They need a bigger intake valve and some bowl blending and short turn work. Nothing drastic to make them support 750hp.
    A month ago I was local in CA but now, not so local any more. (In N/E Tennessee)
    SoCal
    Lucky you! Congratulations on your escape. Who would you recommend. Clay Smith did all the machining and balancing in 07', maybe take them there.
    [email protected]
    049s will flow to feed a mid 400 inch motor in a heart beat. The BIG thing with them is bowl work and 2.19 intake and at least a 1.88 exhaust. To add would be take out the the casting flash and do a good smooth. I personally think (without knowing if you are running a 4779 side ways or a 6109 inline) That you will create a little tuning work! Not that big a deal to me but worth the learning experience! Also seeing over 7k is realistic with the 049 head ( depending on alot of the added components) Good luck!
