re grinding a roller cam
Results 1 to 5 of 5
    Senior Member racer's Avatar
    Dec 2010
    Default re grinding a roller cam
    please share some info on a good source for changing up a roller cam abit....need someone that has worked with older fords..thanks jeff
    El Cajon, Ca.
    Schneider Racing Cams
    619-297-0227
    Jerry is a pretty savy guy when it comes to cams and has never let me down with his expertise.
    The Bostick®
    Dec 2010
    619-297-0227
    thanks for the info ..will follow up for sure..again thanks,,its hard to get people to share things on here!! jeff
    where are you located ?
    Tri-Cities, TN
    Clay Smith, Buena Park. George will be able to tell you what core it is and if the new profile will go through the heat treat.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
