Motor plate bolt
Results 1 to 13 of 13
Motor plate bolt
    Senior Member Scapegoat's Avatar
    SoCal
    Default Motor plate bolt
    Need help on what size/grade bolts to buy for a 396 chevy front and rear motor plate
    thanks
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Bolt to motor or bolt to rail kit?
    SoCal
    Bolts to mount engine plates
    there enough of the bolts and their size is large enough that plastic would almost work. When it gets to the ones holding the plate to the rail, thats a little different.
    I always run SS allens to hold the motor plate to the engine and never failed one yet.
    SoCal
    Thread pitch and length?
    Quote Originally Posted by Scapegoat View Post
    I take it this is a Chevy!
    7/16-14 in the front
    3/8-16 bellhousing
    You REALLY want me to tell you how long? I'll tell you when you can tell me what size tires my trailer needs. Getoutamuthafuckntape!
    I agree with GN7 on the stainless.
    I have always used 3/8-16 for the diameter. The length will vary with how its being mounted.
    In my opinion and the way I have done it for years is to measure the thickness of the material being bolted together and then buying the bolt that is long enough to have a solid shoulder or shank with a length equal to or very slightly less than the two parts being held together.
    Washers can be used as shims if the shank is only slightly long and if only a few are used.
    Make sure the bolt clamps the material and the nut doesn't just tighten up on the threads at the shank because it's too long.
    Usually a bolt like this ends up being overly long, but the excess threads can be cut off for a normal appearance.
    In many cases each mount will have it's own custom bolts.
    If the bolt used is solid thread, there is very little contact surface and will eventually chew up the hole and not be a good fit.
    You can usually drill or ream the hole to the next larger size if necessary and then use the correct size bolt with a shank.
    3/8-16 bellhousing
    Thats funny, but it's a correct answer.
    You just gave the perfect discription for a plate to rail/footblock bolt. I think he asked about the plate to engine bolts.
    But it was a good post none the less
    As an engineering rule of thumb. The depth of the bolt in the threads should be equal or slightly more than the diameter of the bolt. 3/8 == 3/8 in the hole. 1/2 = 1/2 in the hole. Thats why 3/8" nuts are approximately 3/76ers" thick. Hope this this helps.
    Quote Originally Posted by tigertooth View Post
    Now that is an education post right there!!! Good Job T/T. BTW 8 bolts @ 3/8 and 1 @ 7/16 all coarse thread depending on were the front mount bolts and depth_______ you already got a good come back on that!
    OK Ol guy, can you descripe were those bolts go in the block?
    Every BBC Chevy I have ever mounted took 6-3/8 on the bellhousing(7 if it has a top center bolt) and 4- 7/16 on the front.
    SoCal
    I'll go get a tape measure and my sign, lol
    But really thanks....
