timing ?
Results 1 to 5 of 5
timing ?
    Maple Ridge B.C. Canada
    Default timing ?
    whats the most timing (all in ) I can safely set at? 460,jet,10.6:1 ,94 octane, ex 274h cam,t/r 2x600cfm
    I'm thinking 34 degrees. Thanks
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    I think 36DD would be a good guess ......
    Default 36dd
    Quote Originally Posted by Franger View Post
    That's just for the left one!
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by rogerroost View Post
    Fords dont like a lot of timing, when you put the cam in did you replace the timing set?
    The 460 came 6* retarted..so most guys went with the 429 timing set to get it back to 0.....32*- 35* your ok, But read the plugs
    Forget what Franger said, he's dreamin about Beavers
    Nov 2009
    Jerome, Idaho
    I run a 429 @ 10.5 compression (whistled), mech. roller, I played with timing on the dyno until I was blue in the face, from 32* thru 46*. It loves 40*!!! I wouldn't be a bit surprised if your 460 likes 36 to 38*......................
