[Question] Header issue ... Need thoughts
Results 1 to 7 of 7
    Aug 2012
    Default Header issue ... Need thoughts
    So i f-ered up, didnt burp my boat after i ran in havasu drove back to wyoming and hit a snow storm, looks like the log header cracked, whats the odds in cracked inner and outer? i have to pull it when i get back home i dont have time now before work, or should i just plan on buying a new set? Im so mad at myself right now
    Its pretty slim that you cracked the inner. When the water freezes it put the inner in compression, and much less likely to crack. Even if there is a small crack in the inner, it probaby won't matter. The little water that can get thru the would most likely steam off as fast as it entered. If your worried about it, run it on a hose idling for a couple minutes and see if any of the plugs get wet before you spend the money to get them welded
    Aug 2012
    Thx gn7 the outside crack is prolly 1-1/2 inches long i even blew thru it and it leaks thru i was just worried bout the inside around the exhaust chamber , And im hoping i got most the water out of the block , lol. I have another motor i can put in if anything id just hate to have been so stupid i ruined anything else, but thats what i get tryin to own a boat in the snow when living in the sunshine state all my life, il have to mess with it more and hope for the best when i return home.
    Like Bob said. Most likly ok. Lots of them out there that are welded.
    Quote Originally Posted by roostertail777 View Post
    I understand that is is cracked on the outside. I have seen it many times. I was suggesting that you can run it on a hose and let it idle for a couple minutes, letting it leak into the boat, but check the plugs and cylinders to see it they get wet, BEFORE you spend the money to have them welded. But i doubt they are cracked in the inner wall.
    Aug 2012
    Yeah gn7 i got it, i was pretty much rambling on i got what you said wasnt arguing the fact just flustered and pissed i neglected it lol i appreciate the help thx again
    Just pull it off. Plug 1 hole and put your waterhose on the other. See if it leaks inside. The riser will block the end of it.
