whipple 496ho
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 48
whipple 496ho
    Senior Member I DIG IT's Avatar
    spokane WA
    Default whipple 496ho
    Got a whipple for my 496 ho on the way. Any one have this setup on the boat. Love to talk to you about it.
    Distinguished Member 92562's Avatar
    Murrieta
    Talking
    120 hours with mine and going strong. What would you like to know?
    ---Rob
    spokane WA
    Pm sent
    Senior Member Dunaholic's Avatar
    Anybody done one on a 496 mag?
    Senior Member Buster's Avatar
    Santa Carita,Ca
    I got 250hrs on my HO with a whipple. . What cha need to know ??
    Just another day in paradise.
    Murrieta
    Quote Originally Posted by I DIG IT View Post
    Pm sent
    PM sent back!
    Senior Member KineticoH20's Avatar
    Chino Hills
    Quote Originally Posted by Buster View Post
    OK, 1, is the motor stock, 2, who did your install, 3, did you add any engine mods like oil coolers, 4, any engine problems, 5 what octane are you runnung, 6, did you keep the bravo and is it stock, 7, What psi are you runnng, 8, what kind of speed gains did you get. sorry for all the questions but you offered
    Santa Carita,Ca
    Quote Originally Posted by KineticoH20 View Post
    Sure, here you go...
    1 - Yes, it is a stock 05 496 HO
    2 - Flattop Marine in Havasu
    3 - No. Just added a Sea Strainer with it's own pickup for the Chiller. This is a important point as Whipple will tell you to tap the incoming water pickup but that cause the motor to loose water preasure and overheat.
    4 - None so far..
    5 - 91. If I ever have any old gas left in over the winter then I top it off with AV Gas.
    6 - I have a XR drive so it has been fine. I went up four sizes on my prop to a 28.
    7 - 5 lbs
    8 - Almost 15 mph..
    Hope this helps... To me it was worth the money. The boat is turnkey every weekend and is a blast to drive.
    Cheers,
    Murrieta
    Thumbs up
    For me, everything is the same as Buster except I installed it myself (with e-mail support from TPI), and I did switch from the stock 5" long oil cooler to a 12" cooler of the same diameter.
    Drive it smart and it will last. (and make you do this a lot )
    ----Rob
    spokane WA
    Rob got the pm Thank you. I'll be callling before to long thanks again
    Chino Hills
    I would be curious to see how many did it and blew the engine?
    spokane WA
    I really think that this set can work with the proper guides. Stay within the perameters of the motor. Temps are a huge. So is fuel. If done right, the motor will last!!!
    What does this upgrade cost?
    Murrieta
    About $7K for the kit plus another $1+K for rigging hardware,sea strainer, guages, etc. Could be more if you don't have hydraulic steering, good drive, etc.
    ----Rob
