snapped rocker arm
Results 1 to 14 of 16
snapped rocker arm
    Senior Member slotracer's Avatar
    Default snapped rocker arm
    we pulled a valve cover and the #1 stud was snapped off and the #5 had a pushrod that ground through the rocker arm. what could cause this? this is the scond time snapping a rocker stud on #1 its a bbc
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Pat, you've got something going on in the geometry. What rockers? What's the lift on the cam, type of cam, etc? Give as many details as you can.
    Yeah what sc said. First geuss coil bind. M
    cfm
    cfm is offline
    Definately have some incorrect parts choices and/or set-up.
    My first $5 guess with knowing no info yet - stamped steel rockers that aren't clearanced for the valve lift and the slots are hitting the rocker studs. 2nd guess, but just $3 this time, major valve float.
    its has 049 heads, comp cam xm278 cam. stock rocker arms. not sure what springs are in it. going to order some new springs which i should have done to begin with.
    slot
    87 eliminator
    Stockton, ca.
    Get some rockers while you're at it.
    i have a set of roller rockers that i got from someone on the boards i am going to install.
    slot
    87 eliminator
    Stockton, ca.
    cfm
    cfm is offline
    Rockers, springs and related parts, and new (all of them) studs !
    Here's the cam card info:
    http://www.compcams.com/Cam_Specs/Ca...?csid=405&sb=2
    Oh, might want to check the lobes on the cam to see if they are F**d up.
    new arp studs, vavle springs and push rods on order should get them tomorrow. gotta love summit does anyone know the tool to change the springs while they are still on the heads?
    slot
    87 eliminator
    Stockton, ca.
    Nobody
    Big River, Ca
    Here ya go!.
    Tool!
    ordered
    slot
    87 eliminator
    Stockton, ca.
    ok now heres the big question. never done this before what do i need to check for?
    slot
    87 eliminator
    Stockton, ca.
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    If you're planning on doing this while the heads are on the block, You're gonna need this too!
    http://store.summitracing.com/egnsea...=KeywordSearch
    cfm
    cfm is offline
    Don't forget spring height mic's and shims too: http://store.summitracing.com/partde...5&autoview=sku
    The world has everyone making each other think this is a bolt on performance world.......nothing can be further from the truth.
