454 mercruiser 330hp intake, carb, cam
Results 1 to 8 of 8
    Feb 2013
    Default 454 mercruiser 330hp intake, carb, cam
    I am looking for some advice for an intake, cam, and carb for a 1995 baja 240 mercruiser 454. My boat tops out around 60mph and I want to do some upgrades to get that speed up. Exhaust has already been upgraded. I was told I had peanut port heads and may not have a roller cam. Can someone help me on what type of cam I have and how to make some power out of this motor. I normally spin 55-60 mph at about 4800 rpm. Thanks in advance.
    You do not have roller cam, it is a hydraulic flat tappet and it most likely has peanut port heads.
    How much you hoping to gain in speed and how much you willing to speed.
    for any real HP gain you will need to change the heads, cam and valve train to match and the intake manifold. Assuming your exhaust upgrade is up to the job.
    SoCal
    I did exhaust and a edelbrock performer intake on a 330hp 454 in my 21 Vector. I noticed no change in performance. I wasn't expecting any without head and cam changes. I needed to change the stock ones out, they were all in bad shape. Would like to put 049's and a edelbrock performer cam.
    [email protected]
    BLOWN GAS FLAT TO THE RAMP
    REST IN PEACE MY FRIEND
    Feb 2013
    These are some heads that I was thinking about
    http://item.mobileweb.ebay.com/viewi...id=34096689757
    i am wanting to spend no more then 1500. I would like to see 70mph
    Tri-Cities, TN
    I've got a hyd roller that I developed for a customer up for these engines and stock mercury exhaust. With intake manifold and cam change average was about 4mph.
    On a side note. I had a 240 sport and at 70MPH they can get quite interesting to drive.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Tri-Cities, TN
    Quote Originally Posted by 6string View Post
    345cc heads are WAY to big for a 454 turning less that 6000 rpm. It would be a dog with those heads.
    Chris Straub
    Straub Technologies
    Atlanta, Texas, United States
    X2 ..... WAY TO BIG.... would make it a pig indeed.
    Tower Park Resort, Lodi, CA
    Better ways to do it, but on a tight budget... here's my two cents worth.
    Keep your carb, buy a tuning kit, read up on it, learn how it works. I assume it's a Quadrajet... not a bad carburetor by any means, just less understood... $140
    Edelbrock Performer (not Performer RPM), for oval port heads and appropriate carburetor flange... $220
    Summit Cam and Lifter kit #K1301...$100
    Recommended springs for cam above...$90
    Timing chain and gears... $35
    Roller rockers... $250
    Buy a used set of 049 cylinder heads (some for sale here: http://www.performanceboats.com/parts-sale... ) $100-250... and drop them off at a reputable machine shop with your new springs. Cost will vary depending what needs to be done to them or parts that may need replacing.
    Gaskets, lubes, and incidentals... $300-$500
    Depending what second hand parts you're able to source, that should put you right around your budgeted $1500 and put you in the 400(ish)HP range.
    Have you had a chance to play with the trim yet?
