[Question] What Heads are these?
Results 1 to 7 of 7
    Senior Member johnf's Avatar
    Oct 2012
    Default What Heads are these?
    Are these for a 385 ford? No numbers by spark plugs Only 5A16??? x-36 x-38?? Guy says they are for a 460. Thanks I know its a long shot to tell from pics!!!
ID:	270761   Click image for larger version.
    Yes they are 385 heads. Without numbers I couldn't tell you if they are 429 or 460. There are numbers on those heads, you just aren't looking hard enough. Look around the area over the exhaust. See pic
    Oct 2012
    Thank you gn7 Have to drive pretty far to look at heads, He can't find any marks so hopefully I can get some better pics from him.
    San Francisco Bay Area
    Cool
    The heads are D3VE-A2A and the number may be found cast on the underside of the intake runners, like this:
    If so, then they were cast on January 16, 1985. If not, then they were cast on January 16, 1975. Based on some of the valve train hardware, they might have been 460 marine heads but considering they could very well have been reworked since factory it's hard to say from the pictures posted.
    LO
    High Flow Dynamics
    Cool
    There are 385 Series cylinder head casting numbers missing from the above pictured list, and there are also head casting numbers listed that do not exist within the 385 Series cylinder head family (the incorrect casting numbers shown above are actually associated with another Ford engine family).
    Missing: C8VE-E; D0VE-A, D1VE-AA, D2VE-AA, D2VE-A2A, D3VE-A2A
    Incorrect/non-385 Series: D3AE-A2A, D3AE-FA
    Also, the CJ/SCJ head has a 2.25" intake, not a 2.19" intake as shown in the chart.
    This list is for carburetted heads only.
    LO
    High Flow Dynamics
    Quote Originally Posted by LakesOnly View Post
    LO
    Thanks for the info Paul. You can't trust half the stuff that is published.
    I knew you come on here and add in you expertice and knowledge.
    Oct 2012
    Thanks Paul, and Bob Great help as always!!!(Much Appriciated) They have new valves and valve job, now that I know they fit it will be $125 well spent for my budget build!!!!
