Cam ?
Results 1 to 9 of 9
Cam ?
    Sep 2012
    Default Cam ?
    Putting together 496,10 to1,a.b. impeller,tunnel ram 660s, edelbrock heads 61559 118 chamber 315 intake runners, looking at a mechanical roller lift in. .638 ex. .622 lobe sep is 108, dur @ .050. In 254 ex 264. Just looking for some input on the cam. Thanks
    What type of exhaust you going to run?
    Sep 2012
    Over transom wet,
    Like water injected headers or logs with OT pipes?
    Tri-Cities, TN
    An LSA on a 108 with wet headers and that kind of duration will not work.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Sep 2012
    Thank,s for the info, and they are water injected.
    Sep 2012
    What is a good cam that would work, thanks
    Tri-Cities, TN
    What rpm do you want the power?
    Chris Straub
    Straub Technologies
    Sep 2012
